Add on module warranty
stad12345
If i add a add module to a existing ISR router. How about the warranty for the add on module. Base product is covered for 3 years. Did the add on modules comes with separate warranty (smart net )?
Gregory Garrian
The module would not be covered under the base product SmartNet.  You'd need to speak to your sales rep about adding the module to the existing warranty or get a new one.
