After PCD migration issue
lbevinetto
Hi All
I've migrated CUCM 8.6.2 to 11.0.1 with prime collaboration deployment, now when i go to the prime license manager appear a popup that says "version 8.6.2", also in CUCM if i log in the system, in the first page there is in the top Version 11.0.1, in the bottom version 8.6.2.
I think is a cosmetic issue but i would like to solve.
Attached sreenshot of the issue
Manish Gogna
It looks like the is a customized logon message that you configured on cucm. Go to CUCM OS admin page , then go to Software Upgrade > Customized Logon Message > Then click Delete
Logout and log back in, it will be gone. let us know if it works.
Manish
Aman Soi
could be a cosmetic issue.
what do u get after u login into PLM and CUCM Administration first page?
I just checked logging into CUCM and PLM but not getting the versions below as posted by you.
regds,
aman
Manish Gogna
Manish
Hi Manish
The Issue was solved thanks to your instruction
Thank you very much
Have a good day :)
