Alias is not updated after perform full LDAP sync in Unity
Yangjp715
Level 2
Level 2
Hi all,
We have batch of users need to update sAMAccountName in AD. i have performed full LDAP sync in CUCM and Unity after the change was finished in AD, it is all good in CUCM, but only 50% users in Unity whose alias are updated. The Alias for the rest of users are not updated. Any suggestion?
Suggest you to get in contact with TAC for this.
Response Signature
Is there a way for updating the user id of a specific user in CUCM and Unity instead of performing full LDAP sync?
check if there is a dir sync service running on the unity connection and if yes try to restart it. then go to users / sync and find the user which should be synced and try to sync the account
