Applying QoS for collaboration environment
I want to apply QoS for my collaboration network, so what I need is to match some kind of traffic with a especific value of DSCP. In this regard I need to know what are the ports used by cisco jabber for windows. Do you know this?. Thanks!!!
Cisco Jabber
Table 3 Cisco Jabber for Windows port usage
Port
Protocol
Description
Inbound
16384 to 32766
UDP
Receives Real-Time Transport Protocol (RTP) media streams for audio and video. You set these ports in Cisco Unified Communications Manager.
Outbound
69
UDP
Connects to the Trivial File Transfer Protocol (TFTP) server.
6970
HTTP
Connects to the TFTP server to download Cisco Jabber for Windows configuration files.
80
TCP (HTTP)
Connects to services such as Cisco WebEx Meeting Center for meetings or Cisco Unity Connection for voicemail.
143
IMAP (TCP)
Connects to Cisco Unity Connection to access, download, and play voicemail messages.
389
UDP / TCP
Connects to an LDAP directory service.
3268
TCP
Connects to a Global Catalog server for contact searches.
443
TCP (HTTPS)
Connects to services such as such as Cisco WebEx Meeting Center for meetings or Cisco Unity Connection for voicemail.
636
LDAPS
Connects securely to an LDAP directory service.
3269
LDAPS
Connects securely to the Global Catalog server.
993
IMAP (SSL)
Connects to Cisco Unity Connection to retrieve and manage the list of voice messages for the user, and the voice messages themselves.
2748
TCP
Connects to the CTI gateway, which is the CTI Manager component of Cisco Unified Communications Manager.
5060
UDP / TCP
Provides Session Initiation Protocol (SIP) call signaling.
5061
TCP
Provides secure SIP call signaling.
5222
TCP (XMPP)
Connects to Cisco Unified Presence for instant messaging and presence.
7993
IMAP (TLS)
Connects to Cisco Unity Connection to access, download, and play secure voicemail messages.
8191
TCP
Connects to the local port to provide Simple Object Access Protocol (SOAP) web services.
8443
HTTPS
8443 is the port for web access to Cisco Unified Communications Manager and includes connections for the following:
  • Cisco Unified Communications Manager IP Phone (CCMCIP) server for assigned devices.
  • User Data Service (UDS) for contact resolution.
16384 to 32766
UDP
Sends RTP media streams for audio and video.
53
DNS
Provides hostname resolution.
1080
SOCKS5 Bytestreams
Sends peer to peer file transfers. If port 1080 is in use, Cisco Jabber for Windows attempts to use the next available port in the range from 1081 to 1089. In on-premises deployments, Cisco Jabber for Windows also uses this port to send screen captures.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/vxc/english/vxme/9-x_ports_ref/b_vxme_ports-reference-guide.html#reference_C00D2A3EE122415385C77A53ED5CDC2B
refer below docs for QOS configuration and assistance:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/9_7/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97_chapter_01.html#JABW_TK_S11EF173_00
https://technet.microsoft.com/en-us/library/cc771283(v=ws.10).aspx
Venkatesh.
-Do rate all helpful posts.
Cisco Jabber
Port
Protocol
Description
Inbound
16384 to 32766
UDP
Outbound
69
UDP
6970
HTTP
80
TCP (HTTP)
143
IMAP (TCP)
389
UDP / TCP
3268
TCP
443
TCP (HTTPS)
636
LDAPS
3269
LDAPS
993
IMAP (SSL)
2748
TCP
5060
UDP / TCP
5061
TCP
5222
TCP (XMPP)
7993
IMAP (TLS)
8191
TCP
8443
HTTPS
16384 to 32766
UDP
53
DNS
1080
SOCKS5 Bytestreams
Venkatesh.
