Arc enterprise 5 - phone BLF issue for two same DN
cjrchoi11
-line1=1000 with pt_internal, cfb=line2
-line2=1000 with pt_internal_2nd
I installed Arc enterprise version 5 and want to monitoring the BLF status for line1 only. line2 is just roll-over purpose in case line1 busy but the Arc is random to monitoring the BLF (line1 or line2).
Looks Arc is not capable monitoring specific partition only.
Advise please whether it's current design or workaround.
Tommer Catlin
what version CUCM are you running?
CUCM6.1.3
You may want to contact ARC, I cant recall which versions, but I know in 7.02 there are issues with BLF. It could be the same in your version as well.
