ASCII field speed dial
waqas sardar
We are adding speed dials on  Cisco 7961 phone but we can not see the ASCII filed in speed dial.
Due to this, we are facing issue, only display number but no name on the phone screen .
Is there any service to enable ASCII ?
Manish Gogna
Hi Waqas,
How are the speed dials being added? Can you share the exact procedure.
You can use BAT as per the procedure outlined here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/8_6_1/bat-861-cm/t03phtmp.html#wp1207656
Manish
- Do rate helpful posts -
