Ask Me Anything - Drive to 15X
Brooke Hammer
Community Manager
Community Manager
Ask Me Anything Forum - Drive to 15X
Welcome to the Cisco Support Community Ask Me Anything discussion! Are you considering upgrading or migrating your UC applications to version 15.x, such as CUCM, CUC, IM&P? If you're looking to learn more about the features and enhancements in the 15.x release, as well as explore upgrade paths and migration options, you've come to the right place. Our experts are here to address your inquiries and provide valuable insights to help you plan your upgrades or migrations effectively. Join us for this AMA session, starting April 29th, where we'll delve into the critical aspects of version 15.x and offer guidance on your upgrade or migration journey.
Helpful Resources:
CUCM and IMP - https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/docguide/15/cucm_b_documentation-guide-cucm-imp-release-15.html
CUC - https://www.cisco.com/c/en/us/support/unified-communications/unity-connection-version-15/model.html
PCD - https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/15/cucm_b_pcd-admin-guide-15.html
To participate in this event, please use the reply.png button below to ask your questions
Ask questions from Monday, April 29 to Friday, May 10, 2024
Our experts
mjunnur.jpgManjunath Junnur is a Technical Leader in the Collaboration technology team in the Asia Pacific time zone. He has over 12 years of experience in Cisco Unified Collaboration. Currently, he is associated with Collaboration TAC and focuses on CUCM installations, upgrades, and other related issues. He holds certifications such as Cisco Certified Internetwork Expert (CCIE) Collaboration, SIP School Certified Associate, and VCP
kg.pngKevin Gareis is a Technical Consulting Engineer on the Cisco CUCM TAC team in the Pacific time zone but located in Richardson Texas. He has been on the team for 9 years and is currently working as the Escalation Engineer. He has wide expertise in troubleshooting Cisco CUCM, Cisco Emergency Responder and Cisco IP phone solutions. He holds a bachelor’s degree in Information Technology and is CCNA certified.
mS.pngMohammed Shoeb is a Technical Consulting Engineer on the Cisco CUCM TAC team in the APAC time zone located in Bangalore, India. He Has an experience of around 10 Years. He has wide expertise in troubleshooting Cisco CUCM, Cisco Emergency Responder and Cisco IP phone solutions. He holds a bachelor’s degree in Electronics and Communications and is CCIE Collaboration certified.
For more information please visit; Collaboration / Unified Communications Infrastructure.
* This event is free and open to all audiences, including business partners, network and telecommunications engineers, students, and Cisco customers.
17 Replies 17
anika.shah1213
Current CUCM version is 12.5 with 80 GB disk size, can we upgrade to version 15 by expanding the disk size to 110?
No. You cannot expand the disk. You need to re-deploy and install the Node from scratch (Check out "Fresh Install with Data Import")
Unfortunately, no. When you expand the disk size, all of the additional space is automatically allocated to the common/logging partition. As a result, your "active" partition, which is where the CUCM OS resides, will remain the same and be inadequate.
You will need to:
1 - Backup your current 12.5 cluster.
2 - Create a new virtual machine using the defined/necessary specifications (CPU/RAM/Disk):
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html
3 - Install your current version of CUCM 12.5 on the new VM.
4 - Restore from backup on the new VM.
5 - And then you can upgrade to version 15.
Can you migrate straight from from 12.5 with an 80gb disk to 15 or 15.1 with a 110gb disk using export/fresh install with import or PCD, or do you have to get 12.5 on a 110gb OVA first, then upgrade?
You do not need to have 12.5 on a 110GB disk, you can use data import or PCD migration from the 80GB on 12.5 to 110GB on 15. However if you actually want to do an upgrade, you’ll need to follow the steps shared by @kgareis
Response Signature
Will CUCM be supported via KVM. We have lots of customers that don't want to run vmware. Any news on this ?
CCIE-Collaboration #24527
No only ESXi is supported.
Response Signature
I know that :), I asked will it be supported ?  is there a plan in place or shall I just tell me customer to go else where ?
Per the information shared by the BU there are no plans to support any other hypervisor.
Response Signature
I'm sorry, but no. There is no plan in place to support bare metal installations for CUCM.
KVM is a HyperVisor , not baremetal.
i.e.
Kernel-based Virtual Machine - Wikipedia
Hafthor,
My apologies, for some reason my mind went to physical "keyboard video mouse" (KVM).  In that case, Roger is correct, ESXi is the only supported hypervisor and there are no plans in the pipeline to add any other hypervisors to the supported list.
Thats sad to hear, and strange since cisco supports so many other products on KVM, like Cisco ISE. After vmware change their prices running CUCM on vmware is much more expensive for many customers. Specifically, those that are running in bigger environments.
Thanks for the answers, I guess I have to take this up with our Cisco team.
David.roseSC
Installed RTMT tool but unable to launch RTMT on windows for version CUCM 15.x. Thanks for the help
