Audio File Format
mohamed-gheta
Dear Friends,
As far as I know that CVP4 and CVP7, VoiceXML supports the hereunder formats
CCITT, A Law, 8 bits, 8000 HZ sample size, mono
Is there any documents to prove to customer that this is the right format, as the customer recorded the audio files as sterio
Please advise,
Mohamed Gheta
Rob Huffman
Hi Mohamed,
Maybe these will help;
Prerecorded audio file quality must be designed so that it does not impact download time and browser interpretation. Make recordings in 8-bit mu-law 8 kHz format.
Design Implications for VoiceXML Server
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/customer_voice_portal/srnd/7x/cvp_vxml.html
A2 Q. Which audio file formats is supported?
Only au audio files are supported.
The format is 8000 HZ sample rate, Mono, 16-bit, 8bit mu-Law encoded
http://www.cisco.com/warp/public/570/support_cent/vxml/vxmlfaq.html#A2
Cheers!
Rob
Hi Rob,
Thanks so much for your valuable input, but we already used the format indcated below;
  • Bit Rate: 64 kbps
  • Audio sample size: 8 bit
  • Channels: 1 (mono)
  • Audio sample rate: 8 kHz
  • Audio format: CCITT A-Law
  • We have new customer and he recorded the ,wav file with the same format indicated, but sterio no mono, that is why we have impact later on, so we need to give him document approved by Cisco, as he recorded 1000 wav files, so you can imagine
    Again, thanks and wish to get more support from our experts in Cisco NetPro
    Have a nice day,
    Mohamed Gheta
    konlayoot
    which software are u using. I can not find it.
