Auto Dial some random number when picking up hand set
phamvinhdat
Level 3
Level 3
I have several users experience this issue that when they are picking up a handset to dial a number. But the phone automatically dial some random number, and it has happened a lot. Is there any option in CUCM 8.0.3 to turn this auto dial function off.
Thanks.
Dat Pham
Jaime Valencia
Are there PLARs configured??
There are no settings for what you're looking for, dialing random numbers is not a feature/function
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
There are no  PLARsconfigured as I am aware of. This is the first time that I saw this issue.
Thanks.
Dat
fkarami
Hi Dat Pham,
This is usually the behavior of a phone that is configured with a CSS that is configured with a partition that contains a translation pattern with a blank translation pattern string. This results is Cisco CallManager immediately matching this pattern. The translation pattern then transforms the called number (i.e. none) to the destination number (Hotdial) where we want the call sent.
Please have a look at the following link which explains how to configure Hotdial:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
Hope this infoprmation helps.
Cheers,
Farbod
