03-28-2013 04:45 AM - edited 03-19-2019 06:29 AM
Can the BE6K support 5 Cisco UC Apps?
ie
CUCM
CUC
CUPS
CCX
CUPAC
I have created a BOM using QPT with full HA for all Apps and it has output 2x UCS 220M3. I was under the impression BE6K only supports 4 Apps + CUPM so how would this fit on two servers?
Rich
03-28-2013 06:57 AM
I believe B6K can support 5 apps now as long as you do not oversubscribe the resources.
HTH,
Chris
03-28-2013 07:05 AM
Hi Chris,
The 5 Apps is 4+1 (CUPM). Hence my confusion as to how QPT outputs 2xUCS servers with full HA. BE6K can't support 5+1 (CUPM).
Rich
