BE6S-PRI-M2-K9 IP phone door Bell Integration
Inderpal Oberoi
Hello Team,
I need to know what options are available with BE6S-PRI-M2-K9 for IP phone door bell integration.
Any document explaining this would be very helpful ?
Inderpal Singh
skilambi
Inderpal
If this is a plain jain analog device use FXS, otherwise look at IP vendors like this
http://www.2n.cz/en/products/intercom-systems/analog-intercoms/helios/
skilambi
Inderpal
Hi Srinivasan,.
Thanks for your response.I saw documents related to CME and IP phone door bell using FXS, but did not find anything documents for BE6S platform mentioned with FXS port.Do we see any difference in terms of Configuration when using the above platform with Spare FXS port.
Inderpal Singh
Just follow the same process that you have used with ccm like you did in the past since be6ks is just ccm under the hood
Srini
