Beginner Unity Connection question
mark.mclaughlin
I have a very simple beginner question I would've thought would be really easy to find the answer, but so far, I have not.
To set up a call system call handler for your basic company main number, do I need a physical phone with the number attached to a line.
I've tried it without the physical phone and can't get it to work, but with a line, no problem?
thanks
3 Accepted Solutions
Jaime Valencia
No, you can simply configure a CTI RP with CFA to VM, I'm assuming you're using CUCM.
java
if this helps, please rate
Hi Mark,
Some people use the press * during a user greeting to access
their voicemail remotely
But as you nicely noted, a more common remote access
config would be to use a DID for your VM pilot number or at least route
a DID to your VM pilot number for easy access to the Sign-In
conversation.
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
Hi Mark,
Sure, a CTI-RP is a perfect way to go about this. That is how our
remote DID is set up :)
Cheers!
Rob
6 Replies 6
mark.mclaughlin
sorry should've mentioned v. 8.6
Jaime Valencia
java
Thank You.
Figured it would be fairly simple, just needed to know where to start.
This might be the answer to another beginner question I have been thinking about also.
Is it common for users to call their own number when they are calling in from outside to pick up vm and then press * to access?
The Meridian system we are tossing has a common DID number, but the way our vm was setup, the number is internal. I'm not sure if calling your own number is common or if I need to make a new number, or another CTI rp sort of thing and forward to internal vm DN.
Hope that makes sense.
Hi Mark,
conversation.
Cheers!
Rob
- Dylan
Thanks, would using a CTI rp, be the most efficient way of doing that?
Hi Mark,
Cheers!
Rob
