Bulk Export in Unity Connection
pvarenholt
Level 5
Level 5
Trying to get out some information from UCXN.
I realize there is a Bulk Export however looking specifically for the zero out destinations for each mailbox.
Any chance there is a way to do this?
Don't care if it has to be command line but would appreciate any direction someone could provide on this.
Paul.
cbarlow
Hi Paul,
Check out the User Data Dump tool:
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm
In particular, the "Caller Input Key Actions" field should give you this information.
Chris Barlow
Unity Connection Product Manager
Perfect!
Thanks much.
Always forget to look at the tools.
Paul.
I can confirm this works with Cisco Unity Connection version 11.5.1
I followed the instructions, installing the IBM SDK then installing the Unity Connection User Data Dump tool.
I had to assign "Remote Administrator" role to my account and I was off to the races. If you mess up and don't assign the role - the dump tool will fail the login process. You will then need to exit out of the program completely and re-attempt the login
Exporting 7,000 users with about a dozen fields selected takes about 30-40 minutes to dump.
