10-01-2012 04:19 AM - edited 03-19-2019 05:37 AM
Dear Friend,
I have a question regarding the call forward. My requirement is, When I call Forward my IP Phone extension to be redirected to my mobile phone, and if someone calls my IP Phone extension, the call should originate from my IP Phone instead of the caller party. Also my mobile should display my IP Phone extention instead of the caller party. Can someone help me with this?
Thank you,
Ifthiquar.
10-01-2012 02:27 PM
You can use translation pattern which would be matched based on the Forward All CSS assigned to the DN.
So configure new Parition (ForwardPT)
configure new CSS that matches this PT
Assign this CSS under call forward All CSS on the DN
Add TP that matches your mobile DN, change "Calling Party Transform Mask" to be your internal DN
Then depending on how your route patterns are created you may need to add new Route Pattern that matches your mobile number to ensure "Use Calling Party's External Phone Number Mask" is not checked on it to display your internal DN all the way.
Keep in mind though that some providers will reject calls or overwrite the caller ID with BTN number if incorrect caller ID is presented.
HTH,
Chris
10-03-2012 01:05 AM
If you want to do it globally you can also change your "
Have a look at:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080618a74.shtml
It's an old doc but explains the options.
Matty
