Call Forwarding Not working
scooter817
Level 2
Level 2
Hi all
I wanted to know can someone tell me what can I check on a 7945 to get the CFwdALL to work. The user is trying to forward their calls to their cell phone and it's not allowing them to. I had the user hit the call forward button and usually you get the 2 beeps and then you can input the number.This use is not getting anything when the try to call forward. Thanks in advance for anyhelp and have a great day.
Jaime Valencia
Have you checked the CSS activation policy??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
