Call Handler direct to voicemail
Ed Kender
Hello - I'm trying to figure out if there is away with a call handler that someone can call to go directly into someones mailbox without riging the phone.  Internally the end users dial * and the extension.  How can we do this when someone is external by assigning a DID number and give the option in a call handler.
Aaron Harrison
Add a call handler.
On the appropriate caller input option (e.g. '1') set the Action to be 'user with mailbox' and select the user; then ensure you tick 'go directly to greetings'.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Can the 1 call handler be used for all mailboxes at the branch?  On the old system they had a number and they could type in the mailbox number and leave a message.
