04-04-2006 09:54 AM - edited 03-18-2019 05:45 PM
i am running Unity 4.0(4) SR 1 and i have an office configured for caller input with attempt to transfer. when a caller selects the person to transfer to and that phone is forwarded to voice mail the caller hears "wait while i transfer your call" then the caller gets dropped.
any ideas?
thanks in advance.
04-04-2006 10:21 AM
Hi -
You may be introducing an inadvertent loop, which Unity will recognize and not allow, if you have Supervised Transfer set in your call handler. If so, change the transfer type to Release to Switch instead.
Ginger
04-05-2006 04:49 AM
Hi-
On Programs --> Unity use the call viewer to determine what is the extension having this problem. This utility will show you the forwading extension as well as the dialed number.
Open the window, make a call and see what happens. Every call routing has a forwarding station. Based on the output you can determine which call handler is causing this problem and then configure it properly.
Let me know if it helps.
04-05-2006 08:00 AM
Go to Unity tools depot and select two option port status monitor other is callviewer open them simultanesouly when the call will come check the Unity Port number in Call viewer and then at the same time open that port in Unity to see how exaactly that call is coming in and goin out
Cheers :)
Gaurav
05-12-2006 07:25 AM
I have the same issue. I changed the Call Handler or Mailbox to supervise transfer and it works. However, when the phones are not forwarded, the incoming calls from the Auto Attendant say from Voicemail, which my client does not like.
