Calling Party Transformation Mask is not working in RP and RG Level.
ccg-collab1
Level 2
Level 2
Hi All,
Would like to have your inputs why the calling party transformation mask is not working when calling outbound.
This is our setup
GRC_TEST_RL
Cube_RG ------------------------------> Calling Party Transformation Mask Configured
SMW_E1_1_RG ---------------------> Calling Party Transformation Mask Configured
SMW_E1_2_RG ---------------------> Calling Party Transformation Mask Configured
Route Pattern
9.00!
Gateway/Routelist
GRC_TEST_RL
The partition of route pattern is GRC_Outbound_Test located under GRC_CSS_Test
The IP Phone already using the GRC_CSS and when we tested in the DNA it is successfully route and there is the calling party transformation mask.
Call flow
IP Phone -------> CUCM ---------> CUBE
Appreciate your feedback. Thank you
Suresh Hudda
Have you checked calling number on cube ? If it is correct at cube means cucm sending correct calling number to cube  and then you may check with service provider.
Suresh
