01-01-2024 02:12 AM - edited 01-01-2024 02:17 AM
I recently got a UC520 off marketplace, and I'm wondering that how can I upgrade the software pack to 8.6.2. with the device having 128mb of storage so I can run my CP7970, just for now, my only way to get the 7970 working is that I have to reset the phone by connecting it to the TFTP server, and whenever I plug it back in to the UC520, it sometimes works, and it sometimes doesn't after a restart.
And also, another question is that will the license be deleted if I factory reset the device? because I have no information about the license, but it has a license on it which is this:
Solved! Go to Solution.
01-04-2024 01:29 AM
The answer to the first questio is: If you create a VLAN on UC500 it would start to TAG the L2 traffic on the GigabitEthernet interface with the defined VLAN ID so the Switch port where the UC is connected to, should be configured as Trunk Port allowing defined VLANs on UC.
The second question: for sure you will lost the communication with the UC so you should be connected to the console port before proceeding on factory reset.
Please let me know if you have further queries.
Carlo
01-04-2024 03:08 AM
Hi.
You should use a console cable to connect to the UC500 console
not an Ethernet Cable
Use a software suche as putty or moba term to connect.
Carlo
01-01-2024 08:56 AM - edited 01-01-2024 08:57 AM
Unfortunately UC520 went in EoL ages ago and software is no longer available on cisco side. A factory reset does not wipe the license just removes all the configuration.
Carlo
01-01-2024 10:31 AM
Hi, thank you very much for your help and information, I understand that now the UC520 doesn't have any available software.
I am now trying to rest the device, but I am encountering a problem, which is this:
Happy New Year!
rodinardavani
01-01-2024 12:18 PM
Happy new year you too!
I prefer reset the config via CLI
UC520#service in0/0 session
se-10-1-10-1#offline
se-10-1-10-1(offline)#restore factory default
Please let me know
Cheers
Carlo
01-04-2024 12:48 AM
Hi, I have 2 questions, so first thing is that I have lost the voice VLan on the UC520 and when I try to create/modify the VLan, the UC520 becomes unreachable, and I have to hard re-start it (unplugging it and plugging it back). (Please refer to screenshots)
2. I would like to reset the UC520 to factory defaults, but any way that I try, I cannot reset it because the device will become unreachable again. (please also refer to screenshots)
Please note that I am not a pro in networking, so please kindly let me have clear and basic answers
01-04-2024 01:29 AM
Carlo
01-04-2024 02:27 AM
Thank you very much for your prompt reply. I will try your suggested solutions, also another question, If I want to plug the ethernet to the console, should I use telnet/CLI? if yes, may you please help me with the commands?
01-04-2024 03:08 AM
Hi.
Carlo
01-04-2024 03:20 AM
Thank you very much for your information!
Right now, I have ordered the console cable from Amazon, and I will download the putty software. I will receive the cable within few hours. What would be the next stage after I connect to the console?
