CAN NOT MAKE OUTGOING CALLS OR RECEIVE CALLS ON SIP LINE
macdonaldmauye
hello guys please help....
I have a CUCM interfacing with a 2901voice gateway. In the gateway i have configured a SIP trunk from a service provider with IP add 77.X.X.X .
Now i have configured a SIP trunk in CUCM with destination IP 192.168.1.X of the voice gateway and also configured a voice gateway .
i have configured a route pattern poiniting to the SIP trunk i created in CUCM. But i can not seem to receive any calls or make any calls out as i am receiving a busy tone please help someone.
Below is my voice gateway config
dial-peer voice 8677 voip
description DID [263] OUTGOING local calls via VoIP Line
translation-profile incoming IncomingVoIP
translation-profile outgoing DIDCall
destination-pattern [263,0][0,1,2,3,4,5,6,7,8,9]T
session protocol sipv2
session target ipv4:77.[SIP SERVER ADD FROM SERV PROVIDER]
incoming called-number .
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte h245-alphanumeric h245-signal cisco-rtp
no vad
dial-peer voice 1000 voip
description *** H323 TRUNK TO CUCM ***
destination-pattern 1...
session target ipv4:{CUCM IP ADD}
voice-class codec 1
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
dial-peer voice 1001 voip
description *** CALL AA SHORT CODE ***
destination-pattern *89
voice-class codec 1
no vad
sip-ua
credentials username 263[SIPNUMBER] password 7 040A5E545D701C18584F5654 realm sip.zol.co.zw
authentication username 263[SIPNUMBER] password 7 040A5E545D701C18584F5654 realm sip.zol.co.zw
registrar dns:sip.zol.co.zw:5060 expires 1800
sip-server dns:sip.zol.co.zw:5060
5 Replies 5
Jaime Valencia
OK, so, you have a SIP trunk on CUCM, but you're using H323 dial peers in the GW??
You should be using SIP all the way to avoid problems with protocol translation, fix that.
No idea about your dial plan or CUCM configuration, but looking at this:
[263,0] -> Not sure if you think this would match calls that start with 236 (as a 3 digit number) or 0, but that's not how it works, this matches a SINGLE DIGIT that can be 2 OR 6 OR 3 OR 0
[0,1,2,3,4,5,6,7,8,9] -> You can simply replace this with a dot .
What troubleshooting have you done so far?
java
if this helps, please rate
my apologies the h.323 dial peers are for the intergration between te cisco cucm and the avaya IP500v2 unit.
Thanky you let me change on the dial plan
Aseem Anand
can you do the following:
conf t
no logging console
no logging monitor
no logging rate-limit
no logging queue-limit
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
logging buffered 5000000 debugging
service sequence
Enable the below debugs:
Debug ccsip messages
debug voice ccapi inout
Make a test call and share the debugs
Aseem Anand
end
on debugging ccsip messages if i make an outgoing call the call is silent for a moment then gives a busy tone but i can not get any output of the debug on the voice gateway
macdonaldmauye
Hello guys...
So what i did i changed the session target ipv4 address and also instade of using resistrar and sip-server dns i used the IP addesss.
and my sip line registered.
Next i created an h.323 gateway from cucm to voice gateway and configured my routes and my phones could dial out and receive.....Thanks very much for your help.
