Can't Recieve Calls on my Analogue phone (port 0/0/0)
NelsonCBN
I I have configured the following dial peers on my UC560. I can call out but when a call comes in, it doesnt get to the analog telephone on the voice port 0/0/0.
What am I not doing well?
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/3/0:15
dial-peer voice 90 pots
destination-pattern .T
port 0/3/0:15
dial-peer voice 10 pots
destination-pattern 99043700
port 0/0/0
forward-digits all
12 Replies 12
Chris Deren
Please post "debug isdn q931" and "debug voice dialpeer"
Chris
debug isdn q931
*Apr 26 13:31:45.043: ISDN Se0/3/0:15 Q931: Received SETUP  callref = 0x8A73 cal
lID = 0x000B switch = primary-net5 interface = User
*Apr 26 13:31:45.047: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x
8A73
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
*Apr 26 13:31:45.051: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8A
73
*Apr 26 13:31:45.391: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref =
0x0A73
*Apr 26 13:31:45.391: %ISDN-6-CONNECT: Interface Serial0/3/0:29 is now connected
to 8131694027 N/A
*Apr 26 13:31:49.035: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0
x0A73
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Apr 26 13:31:49.035: %ISDN-6-DISCONNECT: Interface Serial0/3/0:29  disconnected
from 8131694027 , call lasted 3 seconds
*Apr 26 13:31:49.035: ISDN Se0/3/0:15 Q931: call_disc: PI received in disconnect
; Postpone sending RELEASE for callid 0xB
*Apr 26 13:31:49.039: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8A
73
*Apr 26 13:31:49.203: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x0A73
debug voice dialpeer:
CBN-AFRICA#debug voice dialpeer Se0/3/0:15 Q931: Sending SETUP
voip dialpeer default debugging is on99: //-1/9025F1B98046/DPM/dpMatchPeer
CBN-AFRICA#l history
*Apr 26 13:35:36.707:
e=DIALPEER_INFO_SPEECH
*Apr 26 13:35:36.707: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2
*Apr 26 13:35:36.707: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Calling Number=8131694027, Called Number=3700, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Apr 26 13:35:37.059: %ISDN-6-CONNECT: Interface Serial0/3/0:29 is now connected
to 8131694027 N/A
*Apr 26 13:35:43.015: %ISDN-6-DISCONNECT: Interface Serial0/3/0:29  disconnected
from 8131694027 , call lasted 5 seconds
*Apr 26 13:35:43.023: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=.T, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
*Apr 26 13:35:43.023: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
This debug shows that call is matching dial peer 2 (which you did not provide) on the inbound side, but then is unable to match any outbound dialpeers, the called number here shows 3700, yet your dial-peer 10 has destination-pattern  99043700.
Chris
Chris, I changed the dial-peer from 10 to 2 ten is off now.
my DID   number is 099043700 (why is it showing 3700?)
*Apr 26 13:42:02.271: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr 26 13:42:02.271: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Apr 26 13:42:02.623: %ISDN-6-CONNECT: Interface Serial0/3/0:30 is now connected
to 8131694027 N/A
*Apr 26 13:42:08.183: %ISDN-6-DISCONNECT: Interface Serial0/3/0:30  disconnected
*Apr 26 13:42:08.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr 26 13:42:08.187: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Is this complete debug? It does not show any called number.
Chris
*Apr 26 13:31:49.035: %ISDN-6-DISCONNECT: Interface Serial0/3/0:29  disconnected: L3_ProcessEvent: callref = 0x0000 Corwar
   Calling Number=, Called Number=080
from 8131694027 , call lasted 3 secondsETUP_REQ:U0_SetupReq(nlcb)990437004/0RIC
*Apr 26 13:31:49.035: ISDN Se0/3/0:15 Q931: call_disc: PI received in disconnectMatchPeersCore:aut
no modem enable-dial-peer)#dest
line
        source_id = Q.
; Postpone sending RELEASE for callid 0xB DL_DATA_REQ 0x0More--its - re
*Apr 26 1
*Apr 26 13:31:49.039: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8A 4 int_id = 0x888DC8FC datasize = 49peer v
   Dial String=08036, Expanded String
7303
*Apr 26 13:31:49.203: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = Timeout=FALSE, Is Incoming
*Apr 26 13:25:38.827:   888DC8FC00000300024004000001
0x0A73:44:31
CBN-AFRICA#no debug all lasted no exec s
!R
line
        source_id = Q.
*Apr 26 1
7303
0x0A73:44:31
!R
This is my new dial-peer configurations
dial-peer voice 2 pots
port 0/3/0:15
dial-peer voice 3 pots
port 0/0/0
forward-digits all
dial-peer voice 4 pots
incoming called-number 099043700
direct-inward-dial
IS ANYTHING WRONG WITH IT?
It is showing 4 digits as that is probably how the PRI is defined for sign digits. Simply change your dial-peer 10 to use 3700 as the destination pattern to make it work.
Chris
This is my new debug voice dialpeer:
*Apr 26
CBN-AFRICA#: //-1/9025
CBN-AFRICA#  Peer Info
CBN-AFRICA#ER_INFO_SPE
CBN-AFRICA#
Building
*Apr 26 13:52:30.015: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr 26 13:52:30.015: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Apr 26 13:52:30.363: %ISDN-6-CONNECT: Interface Serial0/3/0:30 is now connected
to 8131694027 N/A
*Apr 26 13:52:31.131: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr 26 13:52:31.131: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Please post your full config.
Chris
This is my running config:
Current configuration : 2060 bytes
! Last configuration change at 14:01:34 UTC Fri Apr 26 2013
version 15.0
no service pad
hostname CBN-AFRICA
boot-start-marker
boot-end-marker
card type e1 0 3
no aaa new-model
network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
license udi pid UC560-T1E1-K9 sn FGL1525141N
controller E1 0/3/0
pri-group timeslots 1-31
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Loopback interface used to manage integrated application module
no ip address
shutdown
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service modue
interface Serial0/3/0:15
no ip address
encapsulation ppp
isdn overlap-receiving
isdn incoming-voice voice
no cdp enable
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/3/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
port 0/3/0:15
destination-pattern 3700
port 0/0/0
forward-digits all
direct-inward-dial
line con 0
no modem enable
line aux 0
line 2
no activation-character
forward-digits all
direct-inward-dial
line con 0
no modem enable
line aux 0
line 2
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
login
end
