ccm upgrade from 6.1
essaki_ihssan
Hi;
I want to upgrade his ccm 6,1 to the newest,
what must be have to do this upgrade???
thanks
ronpatel
Level 8
Level 8
Overall you have to do following
1) See if you hardware support the new release or not.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
If not you will have to purchase new hardware or else you can use old hardware for new CUCM release.
2) Since this is major upgrade you will have to use new licenes also.
3) Direct upgrade from 6.1.4 is allowed till CUCM 9.0. So of you are running 6.1.4, you can upgrade to CUCm 9.x in single step.
You will find exact step in relesae notes of the release which you want to upgrade to.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
