CCX cleaning
technicalBRO
Hello.
Help me clean up the directory on CCX
Total Free Used
Disk/active 27093228K 14960120K 11857860K (45%)
Disk/inactive 26631156K 23801020K 1455524K (6%)
Disk/logging 92746972K 735464K 87224140K (100%)
admin:show tech runtime disk
-------------------- show platform runtime --------------------
The disk usage:
Filesystem Size Used Avail Use% Mounted on
/dev/sda2 26G 12G 15G 45% /
/dev/sda1 26G 1.4G 23G 6% /partB
/dev/sda6 89G 84G 732M 100% /common
/dev/sda3 248M 11M 225M 5% /grub
tmpfs 3.9G 24M 3.9G 1% /dev/shm
I tried everything. Used commands:
file delete activelog cm/trace/ccm/sdl/* noconfirm
file delete activelog cm/trace/cti/sdl/* noconfirm
file delete activelog cm/trace/*/*/*/* noconfirm
file delete activelog cm/trace/*/*/* noconfirm
file delete activelog cm/trace/*/* noconfirm
file delete activelog cm/trace/* noconfirm
file delete inactivelog cm/trace/*/*/*/* noconfirm
file delete inactivelog cm/trace/*/*/* noconfirm
file delete inactivelog cm/trace/*/* noconfirm
file delete inactivelog cm/trace/* noconfirm
file delete activelog cm/log/ris/csv/*
file delete activelog tomcat/logs/ccmservice/log4j/*
file delete activelog /platform/snmp/*/*
0 Replies 0
