certificat usb token.
alforkanehafid
Hi all,
I generate the certificate per usb token, but this certificate is to expire in two weeks.
question :
do I need to use the usb token for generate the certaficats or not.
Thanks for your helps.
Best regards
Hafid
7 Replies 7
Jaime Valencia
If you mean the CTL, yes, the USB token is required to re-run the app and modify/recreate the CTL
Otherwise, you need to mention exactly what certificate you're asking about, not to mention the product/version...
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Many thanks for your response.
The certificate the CAPF to will expire, i dont now if i will need to use the USB Token.
Kind regards
Hafid Alforkane
Hi all,
Any answer Please.
Thanks for your helps in advanced.
Best regards
Hafid Akforkane
yes, you will need the tokens as you will be updating an existing CTL file with a new CAPF cert.
https://supportforums.cisco.com/docs/DOC-18834
Please remember to rate useful posts, by clicking on the stars below.
Many thanks for your reply.
You'll find below the date when the CAPF certficat experid.
Can I generate a new CAPF certificat to increase expiration date (for example 4/12/2014 to 04/12/2019), without generating CTL certificate using the tokens.
Very Thaks for your Helps.
Hi all,
any answer please.
Thanks in advanced.
Best Regards
Hafid Alforkane
Hi All,
The USB Token is require to genreate I new CAPF certificat ?????
Many Thanks in advanced.
Kind regards
Hafid Alforkane
