CISCO 2900 with UNITY EXPRESS won't automatically recording the voicemail anymore
langkusno89
HI Expert, Just wondering if anybody can help me on the issue i'm having currently, I have CISCO2921/K9 with module Cisco Unity Express - Administration (Version 8.6.7) Chassis type: C2921 Chassis serial: FGL19xxxxx Module type: ISM Module serial: FOC18xxxxx SDRAM (MBytes): 512 Installed Languages CUE Voicemail UK English previously all incoming call that unattended will automatically recorded, which now all of sudden not working anymore... i've tried CLI, by executing "reload" command but nothing seems fixed. really need some help here, as few users here missed out they voicemail. Cheers!
HI Jason,
Thanks for your reply,
i did 2-3 times, executing the reload command, but it only does restarting which takes up to 5 minutes for all comes back online, and then nothing solved.
i didn't do the hard restart, i will if that's the issue.
re: config from CUE, may i know which one? i can do the "show run" on the 2900 CLI, and as it has the module for the VOIP which is on the CUE, which not sure how to get the config, or perhaps is this what you need?
*update*
i did hard reset yesterday, but the problem still persist.
jason-mcgee
Level 3
Level 3
When you executed the reload command did it actually restart or did it hang? Did you do a hard restart? Can you post your full config and your VM settings from CUE?
HI Jason,
*update*
