cisco 7821 like 3rd party device on CUCM7.1.5
alexver1978
Hi, can anyone answer on my questions:
1. can i register cisco 7821 like 3rd party device on CUCM 7.1.5?
2. Should i change factory firmware (sip78xx.10-1-1-1SR1-4)?
Thx
7 Replies 7
Manish Gogna
Yes you can do it. There is no need to change the default firmware, it will work with CUCM 7.x
Manish
- Do rate helpful posts -
Manish, as i know, for registration 3-d sip device i should create a new user and set the same username and password on my phone and CUCM(for this device). But i can't find username and password fields in cisco IP phone 7821 menu. Am i right?
it needs to be on the end user page on cucm. Please check the steps outlined here
https://supportforums.cisco.com/document/50491/how-register-third-party-sip-phones-communications-manager
Manish
Hi, i have already read it.
I have created new end user but there are no fields in menu of 7821 phone where i can type Auth ID and password.
Can you share a screenshot of what you have configured on cucm? Are you adding the phone as third party SIP ( basic ) and trying to set the digest user?
Manish
Yes, I am adding the phone as third party SIP ( basic ) and trying to set the digest user.
What should i set on IP phone besides IP address, mask, default gateway and tftp ip address?
Hi, I have the same prob.
I can't register 7821 on CUCM 7.1.5 as third-party sip.
Is this phone supports digest auth?!
