Cisco 8851 to CUE (No Audio)
Luc Boudreau
Hey everyone. Just wondering if someone could look at this debug and sort out why I have no audio when calling CUE. I configured G711u on the dial peer and also the 8851 but I might have missed something. I saw a mention of g729 in the debug but can't see where that relates to my config. See Debug and config
All SIP Call tracing is enabled
VIGCME#
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1862E8F4 with refCount = 1
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x12B3B94 with refCount = 1
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.30.100]:5060, local_address:[ - ]
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1862E8F4
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2000@192.168.30.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.30.100:5060;branch=z9hG4bK16b8f49e
From: "Dartmouth Reception" <sip:101@192.168.30.1>;tag=f8a5c59ce30e00522f57e1a2-26e4638d
To: <sip:2000@192.168.30.1>
Call-ID: f8a5c59c-e30e0026-230411df-696b2604@192.168.30.100
Max-Forwards: 70
Session-ID: 1e1cc56200105000a000f8a5c59ce30e;remote=00000000000000000000000000000000
Date: Mon, 18 Oct 2021 00:58:34 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP8851/12.1.1
Contact: <sip:10260-E57@192.168.30.100:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPF8A5C59CE30E"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Dartmouth Reception" <sip:101@192.168.30.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 352
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 5068 0 IN IP4 192.168.30.100
s=SIP Call
b=AS:4064
t=0 0
m=audio 16548 RTP/AVP 0 8 116 18 101
c=IN IP4 192.168.30.100
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x294A550) with key=[35] to table
*Oct 18 00:58:35.935: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
*Oct 18 00:58:35.935: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
*Oct 18 00:58:35.935: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.30.100,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
*Oct 18 00:58:35.935: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 192.168.30.1 for SIP
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: bind_inuse: 0conn_reuse: 0
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 192.168.30.1
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/State/sipSPIChangeState: 0x294A550 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x12B3B94) counter, current msg->refCount = 2
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
 Freeing NULL pointer!
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x294A550)->last_request = 0x12B3B94, refCount = 2
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/8192/sipSPIExtractSessionID: Parsed localuuid  - 1e1cc56200105000a000f8a5c59ce30e  remoteuuid - 00000000000000000000000000000000
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - 1e1cc56200105000a000f8a5c59ce30eremoteUUID - 00000000000000000000000000000000
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header is present- 1e1cc56200105000a000f8a5c59ce30e
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/sipSPICheckIpip: VOIP dialpeer (peer=0x13474960) found for sip_user: 2000
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/2048/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: 192.168.30.1
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/verbose/32768/ccsip_ipip_media_forking_copy_prev_best_rpid: MF: This is best rpid..
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/verbose/4096/sipSPIUpdateCallingInfoUsingRpidOrFrom: Updating Calling Info with RPID header data
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/verbose/4096/sipSPISetInfoFromRpid: calling host comes from rpid 192.168.30.1
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/4096/sipSPISetInfoFromRpid: Received current remote name: Dartmouth Reception, current remote number: 101
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/4096/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
*Oct 18 00:58:35.935: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentCSTA: No CSTA found in inbound container
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x294A550 key=f8a5c59c-e30e0026-230411df-696b2604@192.168.30.1002000 balance 1
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/8192/sipSPIMatchSrcIpGroup: Match not found on carrier id
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 2000
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 101
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/info/12288/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name Dartmouth Reception, number 101, Calling oct3 0x00, oct_3a 0x81, Called number 2000
*Oct 18 00:58:35.935: //-1/5B83358F804B/SIP/Info/verbose/1024/sipSPIGetViaHostInURLFormat: VIA URL:sip:192.168.30.100:5060, Host:192.168.30.100
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/67584/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 101
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/critical/1024/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/critical/1024/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/critical/10240/sipSPIGetCallConfig: No match found for P-Called-Party-ID
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/65536/ccsip_sipline_set_vrf: Phone number 101 from ccb calling number
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/65536/ccsip_sipline_set_vrf: Obtained phone tag (1) from Dial-peer
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/65536/ccsip_sipline_set_vrf: Got vrf 0 for phone tag 1
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/8192/sipSPIGetCallConfig: VRF id = 0
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/2048/sipSPIGetCallConfig: Peer tag 40001 matched for incoming call
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/1024/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 192.168.30.1 for SIP
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: bind_inuse: 0conn_reuse: 0
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 192.168.30.1
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/2048/sipSPISetAudioForcedConfig: audio forced config is set to FALSE
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/2048/sipSPIGetCallConfig: Media Antitrombone disabled
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/notify/65536/sipSPISetMediaFlowMode: Forcing the flow mode to FLOW-THROUGH for SIP line
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/8192/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/2304/sipSPISetMediaFlowMode: xcoder high-density disabled
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/8192/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/4/update_video_params_from_config: Checking Video Type Rate=-1 video_codec_allowed=1F
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: STUN Usage is not enabled
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=0
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/critical/32768/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
*Oc
VIGCME#t 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/8704/sipSPIGetCallConfig: Incoming: No defer BYE for last
                              call stats
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/1/ccsip_set_srtp_config: No Srtp configure for this leg.
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/8192/sipSPIGetCallConfig: Media forking disabled
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: Dial-peer has no media class recorder.
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/36864/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/32768/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/32768/ccsip_ipip_media_forking_intra_frame_request_config: MF: FIR en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/32768/ccsip_ipip_media_forking_get_forked_leg_config: MF: This leg is not forked call leg.
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/critical/11264/ccsipInitDSCPPolicyInfo: No DSCP Profile configured, No RPH 2 DSCP Mapping and DSCP policing
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/8192/sipSPIGetCallConfig: Initilise the DSCP policy
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/8192/sipSPICheckFAAnatAssymetricOrDO2EO: Not a SIP-SIP call or not in FA mode
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/notify/8192/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Line
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/verbose/2048/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/notify/10240/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Calling name Dartmouth Reception, number 101, Calling oct3 0x00, oct_3a 0x81, ext_priv 0x00, Called number 2000, oct3 0x00
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/critical/10240/sipSPIValidateRequestUri: Not Enabled
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/65536/UpdateSIPDirectVoiceMailNumber: Direct call from SIP line: called number 2000
*Oct 18 00:58:35.939: //-1/5B83358F804B/SIP/Info/info/131072/sipSPIRscmsmAvail: Value returned by check is = 0
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/critical/4096/sipSPICheckOutBoundDpProvisioning: Cannot obtain the the header bitmap
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/critical/8192/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/8192/sipSPIExtractSessionID: Parsed localuuid  - 1e1cc56200105000a000f8a5c59ce30e  remoteuuid - 00000000000000000000000000000000
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - 1e1cc56200105000a000f8a5c59ce30eremoteUUID - 00000000000000000000000000000000
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header is present- 1e1cc56200105000a000f8a5c59ce30e
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4568421C
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/notify/8192/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/8192/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/critical/1024/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/critical/1024/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/critical/16384/sipSPIProcessReplacesHeader: No replaces hdr found
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/verbose/1024/sipSPIGetContentCPA: No CPA found in inbound container
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/verbose/1024/sipSPIProcessCPA: No x-cisco-cpa content found
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/verbose/1/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 16548
SIP: (23) Attribute mid, level 1 instance 1 not found.
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=40001
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: VRF id = 0
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: ip_best_local_address 192.168.30.1 for SIP
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: return addr 192.168.30.1
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.30.1
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/verbose/1/sipSPI_detect_media_loop: Number of media loops detected - 0
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(116) reserved for codec ilbc
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved  as its in use by other codec
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/notify/1/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/8/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/notify/1/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/32/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 0
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 8
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 116
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is iLBC
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 18
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 101
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is telephone-event
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: mer_dtmf_found 0
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/critical/8193/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/1/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=192.168.30.100, dest_port=16548
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
*Oct 18 00:58:35.939: //-1/xxxxxxxxxxxx/SIP/Info/sipSPI_Check_If_ICE_Needed: CANDIDATE attribute, level 1not found.
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec        : g711ulaw, bytes :160
Preferred  DTMF relay  : rtp-nte
Preferred NTE payload  : 101
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media
VIGCME#: No
DSP DNLD Reqd          : No
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/4096/ccsip_offer_ans_handle_rcvd_sdp:
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_RCVD
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/4096/ccsip_offer_ans_is_invite_offer_valid:  TRUE
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/4096/ccsip_offer_ans_common_offer_rcvd_hdlr:
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/4096/ccsip_iwf_handle_network_event:
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_RCVD_SDP
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/4096/sip_iwf_def_ed_rcvd_sdp_hdlr:
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 23 to stream 1. Old streamid = -1
*Oct 18 00:58:35.939: //23/5B83358F804B/SIP/Info/info/1/sipSPI_initialize_audio_channelInfo_from_sdp: stream_callid = 23, peer_stream_callid = -1
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/8/sipSPI_ipip_init_stream_ex_caps_params: T38 version 0
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/8/sipSPI_ipip_init_stream_ex_caps_params: CCB fax rate 2 ipip_caps rate 14400
SIP: (23) setup attribute, level 1 instance 1 not found.
SIP: (23) connection attribute, level 1 instance 1 not found.
SIP: (23) Attribute label, level 1 instance 1 not found.
SIP: (23) a=framerate attribute, level 1 instance 1 not found.
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/1025/sipSPI_initialize_audio_channelInfo_from_sdp: Populating Address in channelInfo
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sipSPI_initialize_audio_channelInfo_from_sdp: Media dest addr for stream 1='192.168.30.100', port=16548
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g711ulaw; PType = 0
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/1/codec_found: Codec to be matched: g711ulaw(5)
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/1/codec_found: Match Found at index 0.
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Add Channel for Codec g711ulaw
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/notify/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Media negotiation done for m-line=1: negotiated_ptime=0, negotiated_codec_bytes=160
*Oct 18 00:58:35.943: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sipSPI_ipip_update_codec_params_in_stream_channelInfo: Adding negotiated codec g711ulaw ptype 0 time 20,   bytes 160 as channel 0 mline 1 ss 1
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/131073/sipSPIBwCacCalcAudioBandwidth: calculated audio bandwidth : codec g711ulaw bw 64000
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g711alaw; PType = 8
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/1/codec_found: Codec to be matched: g711alaw(6)
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/notify/1/codec_found: Match Not Found for g711alaw.
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = ilbc; PType = 116
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/1/codec_found: Codec to be matched: ilbc(33)
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/notify/1/codec_found: Match Not Found for ilbc.
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/notify/1/sipSPI_ipip_update_static_codec_params: An exact codec match not configured, using interoperable codec g729r8
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = g729r8; PType = 18
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/1/codec_found: Codec to be matched: g729r8(16)
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/notify/1/codec_found: Match Not Found for g729r8.
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/32/sipSPI_ipip_upd_2833_dtmf_params: setting ipip_caps DTMF to RFC2833: callid = 23, dtmf = 6
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sip_iwf_sip_copy_audio_sdp_to_local_channelInfo: Processing Media line = 1; Codec = No Codec   ; PType = 101
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/16/sipSPIGetPreferredSrtpSuiteForBw: Return : 0
*Oct 18 00:58:35.943: //-1/xxxxxxxxxxxx/SIP/Info/verbose/16/sipSPIBwCacGetSrtpOverhead: Return: 0
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Media/sipSPIDisplayStreamInfo:
  Stream type            : voice+dtmf
  Media line             : 1
  State                  : STREAM_ADDING (2)
  Stream address type    : 1
  Callid                 : 23
  Peer Callid            : -1
  RTP/SRTP Negotiated     : 8
  Negotiated Codec       : g711ulaw, bytes :160
  Nego. Codec payload    : 0 (tx), 0 (rx)
  Negotiated DTMF relay  : rtp-nte
  Negotiated NTE payload : 101 (tx), 101 (rx)
  Negotiated CN payload  : 0
  Media Srce Addr/Port   : [192.168.30.1]:0
  Media Dest Addr/Port   : [192.168.30.100]:16548
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/verbose/4097/sipSPI_ipip_calculate_channel_count: Number of streams to report = 1
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/critical/1/sip_iwf_sip_copy_sdp_to_stream_channelInfo: Not updating call entry.
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/1/sip_iwf_def_ed_rcvd_sdp_hdlr: Setting media_direction to 4
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted BW Option 0 flow mode flow-through
audio bw 80000 bps video bw 0 bps fax bw 0 bps total bw 80000 bps  accounted bw 0 bps
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/131072/sipSPIBwCacUpdateInterfaceBw: bwcac acquiring interface GigabitEthernet0/0 bw 80
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Info/info/131072/sipSPIBwCacUpdateAccountedBw: bwcac update accounted bw (initial offer) accounted bw set to 80000
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_RCVD_AWAIT_PEER_EVENT
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_RCVD
*Oct 18 00:58:35.943: //23/5B83358F804B/SIP/Media/sipSPIUpdCallWithSdpInfo:
  Media line             : 1
  Callid                 : 23
*Oct 18 00:58:35.999: //23/5B83358F804B/SIP/Info/info/4096/ccsip_offer_ans_handle_update_allowed: flag is set to consume early update
*Oct 18 00:58:35.999: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x457688E8
VIGCME#
*Oct 18 00:58:40.431: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13E2F170 with refCount = 1
*Oct 18 00:58:40.431: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x100D2FC with refCount = 1
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.30.100]:5060, local_address:[ - ]
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13E2F170
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:2000@192.168.30.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.30.100:5060;branch=z9hG4bK572f1647
To: <sip:2000@192.168.30.1>;tag=140E1C-F6F
Max-Forwards: 70
Session-ID: 1e1cc56200105000a000f8a5c59ce30e;remote=4f5dec3b8be95001b71060d33ee95331
Date: Mon, 18 Oct 2021 00:58:39 GMT
CSeq: 102 BYE
Content-Length: 0
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/4096/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x294A550
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x100D2FC) counter, current msg->refCount = 2
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 192.168.30.100,Port 5060, Transport 1, SentBy Port 5060vrfid 0
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/4096/ccsip_set_release_source_for_peer: ownCallId[23], src[2]
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/4096/sipSPIStopHoldTimer: Stopping hold timer
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/4096/sipSPIUreasonHeader_to_ccCause: Cause=0
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/critical/4096/sipSPIInitiateDisconnect: Initiate call disconnect(16) for incoming call
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x12B3B94) counter, current msg->refCount = 1
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQSIG: No QSIG Body found in inbound container
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQ931: No RawMsg Body found in inbound container
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 34
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/critical/10240/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/critical/8192/sipSPI_ipip_IsContentPassthruEnabled:  - 0
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/notify/8192/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/1024/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/State/sipSPIChangeState: 0x294A550 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x12B3B94
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x100D2FC) counter, current msg->refCount = 3
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x294A550)->last_request = 0x100D2FC, refCount = 3
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x100D2FC) counter, current msg->refCount = 2
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 19
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_XCODER_RESET_STREAM
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/256/sipSPIResetXcoder: *****CLEANING UP XCODER RESOURCES*****
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/256/sipSPIResetXcoder: Xcoder resource already cleaned up
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: IPIPMS:next_state:S_IPIP_MEDIA_SERV_STATE_IDLE
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/4096/ccsip_bridge_drop: ReSetting mid call signalling not supported
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/notify/8193/updateGccbTxRxValues: No interworking required for stream type 0
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/notify/8193/updateGccbTxRxValues: No interworking required for nte
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/notify/8193/updateGccbTxRxValues: No interworking required for nse
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/notify/8193/updateGccbTxRxValues: No interworking required for stream type 0
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/notify/8193/updateGccbTxRxValues: No interworking required for nte
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/notify/8193/updateGccbTxRxValues: No interworking required for nse
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/critical/1/sipSPIUpdateMediapolicy: media policy block does not exist
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Media/sipSPIUpdateRtpSession: Stun packet reporting for ICE disabled in sipSPIUpdateRtpSession
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:412C90B4
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 19
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_XCODER_RESET_STREAM
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/verbose/256/sipSPIResetXcoder: *****CLEANING UP XCODER RESOURCES*****
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/verbose/256/sipSPIResetXcoder: Xcoder resource already cleaned up
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/State/ccsip_cnfsm_debugs: IPIPMS:next_state:S_IPIP_MEDIA_SERV_STATE_IDLE
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/verbose/4096/ccsip_bridge_drop: ReSetting mid call signalling not supported
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/critical/1/sipSPIUpdateMediapolicy: media policy block does not exist
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Media/sipSPIUpdateRtpSession: Stun packet reporting for ICE disabled in sipSPIUpdateRtpSession
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4575CD5C
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/8192/ccsip_call_statistics: Stats are not supported for IPIP call.
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/critical/4096/ccsip_ipip_mf_create_xml_metadata_for_disconnect: MF: Not a Forked leg..
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/info/8192/ccsip_call_statistics: Stats are not supported for IPIP call.
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 34
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/critical/4096/ccsip_ipip_mf_create_xml_metadata_for_disconnect: MF: Not a Forked leg..
*Oct 18 00:58:40.435: //24/5B83358F804B/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/133120/sipSPIBwCacReleaseDialPeerBw: bwcac dial-peer bw 80 Kbps released for tag 40001 active bw 0 Kbps
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface GigabitEthernet0/0 bw 80 Kbps
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted  bw 80000 bps
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/4096/act_disconnecting_disconnect: Disconnect now.. no defer BYE..
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x12B3B94 with refCount = 1
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/notify/8192/sipSPIAddSessionID:  localUUID - 1e1cc56200105000a000f8a5c59ce30e remoteUUID - 4f5dec3b8be95001b71060d33ee9533
VIGCME#1
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/notify/8192/sipSPIAddSessionID: Session-ID header 4f5dec3b8be95001b71060d33ee95331;remote=1e1cc56200105000a000f8a5c59ce30e
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 3 event
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/4096/sipSPISendByeResponse: Associated container=0x4568421C to Bye Response
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Transport/sipSPITransportSendMessage: msg=0x12B3B94, addr=192.168.30.100, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x9F43F54
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Oct 18 00:58:40.435: //23/5B83358F804B/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x12B3B94 to default port=5060
*Oct 18 00:58:40.435: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.30.100, rport:5060 with laddr:
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x294A550 is already on connection=0x23B6F10 context_list
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x12B3B94
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x12B3B94, addr=192.168.30.100, port=5060, local_addr=, connId=2 vrfid=0 for UDP
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/info/512/sentByeResponse: Sent 200ok to the BYE, tearing down the call
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/info/4096/sipSPISetCommonTimer: Started generic timer type 2 for 240000 millisecs
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/verbose/8192/sipSPIDeferCallClose: Not split dataplane, bail
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/verbose/8192/sipSPIWaitForStatsBforeCallClose: Not split dataplane, bail
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/verbose/4096/sipSPICallCloseAfterFinalStat:
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/info/12288/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:131880 ConnTime 131435
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Media/sipSPIHandleDestroyRtpSession: stream:412C90B4
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x100D2FC) counter, current msg->refCount = 1
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/State/sipSPIChangeState: 0x294A550 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x294A550
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 101
Called Number            : 2000
Source IP Address (Sig  192.168.30.1
Destn SIP Req Addr:Port  : 192.168.30.100:5060
Destn SIP Resp Addr:Port : 192.168.30.100:5060
Destination Name         : 192.168.30.100
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 192.168.30.1
Source IP Port    (Media): 16420
Destn  IP Address (Media): 192.168.30.100
Destn  IP Port    (Media): 16548
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 17
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Return and SIP_TIMER_REMOVE_TRANSACTION timer will free this ccb=0x0294A550
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/133120/sipSPIBwCacReleaseDialPeerBw: bwcac dial-peer bw 80 Kbps released for tag 2000 active bw 0 Kbps
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface GigabitEthernet0/0 bw 80 Kbps
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted  bw 80000 bps
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/4096/act_active_disconnect: act_active_disconnect: Disconnect now..
                              no defer BYE..
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/4096/sipSPIStopHoldTimer: Stopping hold timer
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x45764AD8 with refCount = 1
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/notify/8192/sipSPIAddSessionID:  localUUID - 4f5dec3b8be95001b71060d33ee95331 remoteUUID - 1e1cc56200105000a000f8a5c59ce30e
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/notify/8192/sipSPIAddSessionID: Session-ID header 1e1cc56200105000a000f8a5c59ce30e;remote=4f5dec3b8be95001b71060d33ee95331
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 3 event
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/4096/sipSPISendBye: mf_xml_metadata is NULL
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/4096/sipSPISendBye: Associated container=0x456834B4 to Bye
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Transport/sipSPITransportSendMessage: msg=0x45764AD8, addr=192.168.30.5, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x9F41B3C
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.30.5, rport:5060 with laddr:
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x2950CB8 is already on connection=0x23B7014 context_list
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x45764AD8
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x45764AD8, addr=192.168.30.5, port=5060, local_addr=, connId=3 vrfid=0 for UDP
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Info/info/512/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/State/sipSPIChangeState: 0x2950CB8 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Oct 18 00:58:40.439: //23/5B83358F804B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 18 Oct 2021 00:58:40 GMT
Server: Cisco-SIPGateway/IOS-15.7.3.M6
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=0,OS=0,PR=159,OR=25122,PL=0,JI=0,LA=0,DU=4
Session-ID: 4f5dec3b8be95001b71060d33ee95331;remote=1e1cc56200105000a000f8a5c59ce30e
Content-Length: 0
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x12B3B94
*Oct 18 00:58:40.439: //24/5B83358F804B/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:2000@192.168.30.5:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.30.1:5060;branch=z9hG4bK17130F
From: "Dartmouth Reception" <sip:101@192.168.30.1>;tag=140E0C-1D89
To: <sip:2000@192.168.30.5>;tag=cue72eb687c
Date: Mon, 18 Oct 2021 00:58:35 GMT
Call-ID: 5B85A6C8-2EE511EC-8051EE15-4B84A76B@192.168.30.1
User-Agent: Cisco-SIPGateway/IOS-15.7.3.M6
Max-Forwards: 70
Timestamp: 1634518720
CSeq: 102 BYE
P-RTP-Stat: PS=159,OS=25122,PR=0,OR=0,PL=0,JI=0,LA=0,DU=4
Content-Length: 0
*Oct 18 00:58:40.439: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x45764AD8
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x45764D80 with refCount = 1
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x12B3B94 with refCount = 1
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.30.5]:32776, local_address:[ - ]
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x45764D80
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invit
VIGCME#e Dialog
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/info/1024/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK17130F from via branch list
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x12B3B94) counter, current msg->refCount = 2
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/sact_disconnecting_new_message_response: [sact_disconnecting_new_message_response] Received Response Class [2] Method Code [103]
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/info/4096/sipSPISetCommonTimer: Started generic timer type 2 for 240000 millisecs
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/8192/sipSPIDeferCallClose: Not split dataplane, bail
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/8192/sipSPIWaitForStatsBforeCallClose: Not split dataplane, bail
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/4096/sipSPICallCloseAfterFinalStat:
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/info/12288/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:131880 ConnTime 131434
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Media/sipSPIHandleDestroyRtpSession: stream:4575CD5C
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x425E41F8
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/State/sipSPIChangeState: 0x2950CB8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x2950CB8
Destn SIP Req Addr:Port  : 192.168.30.5:5060
Destn SIP Resp Addr:Port : 192.168.30.5:5060
Destination Name         : 192.168.30.5
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Dtmf-relay    : 8
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Port    (Media): 16422
Destn  IP Address (Media): 192.168.30.5
Destn  IP Port    (Media): 16934
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 18
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[36] removed.
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/info/4096/sipSPIStopCommonTimer: Stopping Generic Timer 2
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2950CB8 key=5B85A6C8-2EE511EC-8051EE15-4B84A76B@192.168.30.1
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Error/sipSPIFlushDeferredQueue:
 Invalid deferredQueue
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x23B6930, addr=192.168.30.5, port=5060, local_addr=, unregistering context=0x2950CB8
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x2950CB8 from the connection=0x23B7014 context list
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x12B3B94) counter, current msg->refCount = 1
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
*Oct 18 00:58:40.443: //24/5B83358F804B/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x2950CB8
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[36]
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x12B3B94
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/verbose/4096/act_subscription_terminated: Resetting server EDB flag
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/info/4096/sipSPITerminateEvent: 1 Events still active on this Subscription Dialog
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/verbose/4096/act_subscription_terminated: Resetting Client EDB flag
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/verbose/4096/sipSPIFreeOneEDB: There are 1 EDBs on edbQ
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/verbose/4096/sipSPIFreeOneEDB: DeQ'd EDB(0x29612F4)
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIFreeOneEDB: EnQing EDB(0x29612F4) for reuse
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/verbose/4096/sipSPITerminateEvent: Freeing SCB(0x16C55FD8), 0 active events present
*Oct 18 00:58:40.443: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[37] removed.
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/verbose/4096/sipSPIRemoveSCBFromClientTable: Removing SCB(0x16C55FD8) with Key(5B85A6C8-2EE511EC-8051EE15-4B84A76B@192.168.30.1140E0C-1D89) from Client Table
*Oct 18 00:58:40.443: //0/000000000000/SIP/Info/verbose/4096/sipSPIFreeOneSCB: EnQing SCB(0x16C55FD8) for reuse
CONFIG
version 15.7
hostname VIGCME
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
enable secret 5 $1$Z265$k7aI7smCRAqVghX7D4VYQ0
no aaa new-model
crypto pki trustpoint TP-self-signed-694046112
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-694046112
 revocation-check none
 rsakeypair TP-self-signed-694046112
crypto pki certificate chain TP-self-signed-694046112
 certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
ip dhcp excluded-address 192.168.30.1 192.168.30.99
ip dhcp pool Voice
 network 192.168.30.0 255.255.255.0
 dns-server 192.168.30.10
 default-router 192.168.30.1
 option 150 ip 192.168.30.1
 option 66 ip 192.168.30.1
 lease 7
ip cef
no ipv6 cef
voice-card 0
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 600 min 60
  g729 annexb-all
voice register global
 mode cme
 source-address 192.168.30.1 port 5060
 timeouts interdigit 2
 max-dn 200
 max-pool 100
 timezone 14
 voicemail 2000
 tftp-path flash:
 file text
 create profile sync 0004021753180415
 network-locale CA
 auto-register
voice register dn  1
 number 101
 call-forward b2bua busy 2000
 call-forward b2bua noan 2000 timeout 20
 label Dartmouth Reception
 mwi
voice register pool  1
 busy-trigger-per-button 2
 id mac F8A5.C59C.E30E
 type 8851
 number 1 dn 1
 presence call-list
 dtmf-relay rtp-nte
 codec g711ulaw
vxml logging-tag
license udi pid CISCO2951/K9 sn FTX1737AJN7
license accept end user agreement
hw-module pvdm 0/0
hw-module sm 1
file privilege 0
username admin privilege 15 password 0 cisco
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address dhcp
 duplex auto
 speed auto
interface Integrated-Service-Engine1/0
 ip unnumbered GigabitEthernet0/0.20
 service-module ip address 192.168.30.5 255.255.255.0
 !Application: CUE Running on NME
 service-module ip default-gateway 192.168.30.1
 no keepalive
ip forward-protocol nd
ip http server
ip http access-class 50
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash0:/CME-GUI-12.0
ip route 192.168.30.5 255.255.255.255 Integrated-Service-Engine1/0
ipv6 ioam timestamp
nls resp-timeout 1
cpd cr-id 1
access-list 50 permit 192.168.3.0 0.0.0.255
access-list 50 permit 192.168.30.0 0.0.0.255
access-list 50 remark
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2000 voip
 destination-pattern 2000
 session protocol sipv2
 session target ipv4:192.168.30.5
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 3000 voip
 destination-pattern 3000
 codec g711ulaw
 no vad
sip-ua
gatekeeper
 shutdown
telephony-service
 authentication credential voicemail voicemail
 max-ephones 100
 max-dn 100
 ip source-address 192.168.30.1 port 2000
 url services http://10.1.1.2/voiceview/common/login.do
 url authentication http://10.1.1.1/CCMCIP/authenticate.asp
 voicemail 2000
 max-conferences 8 gain -6
 web admin system name voicemail password voicemail
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp 7960 Oct 17 2021 22:49:19
line con 0
 exec-timeout 0 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
line vty 0 4
 password **********
 logging synchronous
 login
 transport input telnet
scheduler allocate 20000 1000
ntp server pool.ntp.org
ntp server
pnp profile pnp_cco_profile
 transport https ipv4
end
After more troubleshooting, a software update on the CUE module has resolved the issue. Was running 7.0.6 and now running 8.6.1. All working as expected now.
13 Replies 13
Your config in the CME router looks good except for needing:
sip-ua
 mwi-server ipv4:192.168.30.5 unsolicited
But that would only affect MWI and not call setup to CUE.
The debug does show that the call is set up with the G711ulaw codec, rtp-nte, and no vad which is exactly right. But the call is not being sent to the CUE.
We see the INVITE come in for the voicemail call, but the SIP description of the dial-peer selection notes that dial-peer voice 2000 is a potential target, but does not use that to complete the call. If it did, we should see an INVITE going from CME to CUE. If I'm reading the debug right, it seems that the router is instead finding the next best match which is destination-pattern (cme virtual dial-peer 40001) against incoming calling party (101).
   **and this line**
We don't see the router reaching out to CUE (192.168.30.5) at all until after the BYE message is issued from the originating device. The odd thing (to me) is that the BYE message is relayed to the CUE when an INVITE was never issued.
So, first, check the status of the CUE dial-peer using show dial-peer voice summary Is dial-peer 2000 showing up?
Regardless, I think the issue is not in your CME config but rather in the CUE config. If you choose to post that, please do so as an attached file instead of pasting the config.
Maren
Thank you for your assistance Maren,
The show dial-peer voice summary is as follows:
VIGCME#show dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS SESS-SER-GRP\  OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE    VRF
2000   voip  up   up             2000               0  syst ipv4:192.168.30.5        NA
3000   voip  up   up             3000               0  syst ipv4:192.168.30.5        NA
40001  voip  up   up             101$               0  syst ipv4:192.168.30.100:     NA
Not sure why 40001 is there or should be there.
CUE Config is as follows:
VIG-CUE# sh conf
clock timezone America/Halifax
hostname VIG-CUE
line console
  exit
system language preferred "en_US"
ip name-server 192.168.30.1
ntp server 192.168.30.1 prefer
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/hsEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
log trace local enable
site name local
 phone-authentication credentials hidden "drsG4RYdBv7YJzZdkFqAGA55cpYFhifeSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
 site-hostname 192.168.30.1
 web credentials hidden "drsG4RYdBv7YJzZdkFqAGA55cpYFhifeSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
 end site
privilege ManagePrompts create
privilege ManagePublicList create
privilege ViewPrivateList create
privilege vm-imap create
privilege local-broadcast create
privilege broadcast create
privilege ViewRealTimeReports create
privilege ViewHistoricalReports create
privilege manage-passwords create
privilege manage-users create
groupname Broadcasters create
username admin create
username dartmouthreception create
privilege ManagePrompts description "Privilege to create, modify, or delete system prompts"
privilege ManagePublicList description "Privilege to manage public lists"
privilege ViewPrivateList description "Privilege to view private list"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP client"
privilege local-broadcast description "Privilege to send local broadcast messages"
privilege broadcast description "Privilege to send local or remote broadcast messages"
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege ViewHistoricalReports description "Privilege to view historical reports"
privilege manage-passwords description "Privilege to reset user passwords"
privilege manage-users description "Privilege to create, modify, and delete users and groups"
privilege ManagePrompts operation system.debug
privilege ManagePrompts operation prompt.modify
privilege ManagePublicList operation voicemail.lists.public
privilege ManagePublicList operation system.debug
privilege ViewPrivateList operation voicemail.lists.private.view
privilege vm-imap operation voicemail.imap.user
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege broadcast operation broadcast.local
privilege broadcast operation broadcast.remote
privilege broadcast operation system.debug
privilege ViewRealTimeReports operation report.realtime
privilege ViewHistoricalReports operation report.historical.view
privilege manage-passwords operation user.password
privilege manage-passwords operation user.pin
privilege manage-passwords operation system.debug
privilege manage-users operation group.configuration
privilege manage-users operation user.configuration
privilege manage-users operation user.notification
privilege manage-users operation user.password
privilege manage-users operation user.remote
privilege manage-users operation user.mailbox
privilege manage-users operation user.pin
privilege manage-users operation system.debug
groupname Administrators member admin
groupname Broadcasters privilege broadcast
username dartmouthreception phonenumber "101"
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
calendar biz-schedule systemschedule
 open day 1 from 00:00 to 24:00
 open day 2 from 00:00 to 24:00
 open day 3 from 00:00 to 24:00
 open day 4 from 00:00 to 24:00
 open day 5 from 00:00 to 24:00
 open day 6 from 00:00 to 24:00
 open day 7 from 00:00 to 24:00
 end schedule
ccn application autoattendant aa
 description "autoattendant"
 enabled
 maxsessions 16
 script "aa.aef"
 parameter "busClosedPrompt" "AABusinessClosed.wav"
 parameter "holidayPrompt" "AAHolidayPrompt.wav"
 parameter "welcomePrompt" "AAWelcome.wav"
 parameter "disconnectAfterMenu" "false"
 parameter "dialByFirstName" "false"
 parameter "allowExternalTransfers" "false"
 parameter "MaxRetry" "3"
 parameter "dialByExtnAnytime" "false"
 parameter "busOpenPrompt" "AABusinessOpen.wav"
 parameter "businessSchedule" "systemschedule"
 parameter "dialByExtnAnytimeInputLength" "4"
 parameter "operExtn" "0"
 end application
ccn application ciscomwiapplication aa
 description "ciscomwiapplication"
 enabled
 maxsessions 16
 script "setmwi.aef"
 parameter "CallControlGroupID" "0"
 parameter "strMWI_OFF_DN" "8001"
 parameter "strMWI_ON_DN" "8000"
 end application
ccn application msgnotification aa
 description "msgnotification"
 enabled
 maxsessions 16
 script "msgnotify.aef"
 parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
 parameter "DelayBeforeSendDTMF" "1"
 end application
ccn application promptmgmt aa
 description "promptmgmt"
 enabled
 maxsessions 1
 script "promptmgmt.aef"
 end application
ccn application voicemail aa
 description "voicemail"
 enabled
 maxsessions 16
 script "voicebrowser.aef"
 parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
 end application
ccn engine
 end engine
ccn reporting historical
 database local
 description "se-10-1-1-2"
 end reporting
ccn subsystem email
 end subsystem
ccn subsystem fax
 end subsystem
ccn subsystem sip
 gateway address "192.168.30.1"
 mwi sip unsolicited sub-notify
 end subsystem
ccn trigger http urlname msgnotifytrg
 application "msgnotification"
 enabled
 maxsessions 2
 end trigger
ccn trigger http urlname mwiapp
 application "ciscomwiapplication"
 enabled
 maxsessions 1
 end trigger
ccn trigger sip phonenumber 2000
 application "voicemail"
 enabled
 maxsessions 16
 end trigger
ccn trigger sip phonenumber 3000
 application "autoattendant"
 enabled
 maxsessions 16
 end trigger
service phone-authentication
 end phone-authentication
service voiceview
 enable
 end voiceview
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail mailbox owner "dartmouthreception" size 3927
 description "dartmouthreception mailbox"
 no fax enable
 end mailbox
end
Dial-peer 40001 represents the dial-peer automatically created by the CME for the 101 DN. Each new SIP DN in CME will create a new dial-peer counting up from 40001. (SCCP DNs in CME are in the 20001 and up range).
The CUE config looks okay to me, so I'm not sure what's going on here. Can you run the following two debugs and post the output?
debug ccsip messages
debug voice dialpeer
Those two debugs will show us the exchange of SIP messages, and also the dial-peer selection process. This will tell us if the CME is sending the call to CUE at all. And, if so, the parameters of the call.
*PLEASE* post the output of the debug as an attached file to your reply. Simply pasting the output into your reply requires some reformatting before analysis. Thanks.
Maren
Hi Maren,
Wondering if you had a chance to review the debugs I posted. Thanks!
So first, I was wrong about the dial-peer selection. The debug voice dialpeer and the debug ccsip messages both clearly show the call flowing through the router to the CUE.
The SDP in the debug ccsip messages also clearly shows g711ulaw being negotiated. I do see the phone's call leg negotiating rtp-nte while the CUE is negotiating sip-notify. They need to match. When I've set up CME/CUE in the past I've used rtp-nte.
In CUE:
ccn subsystem sip
 dtmf-relay rtp-nte
In CME:
dial-peer voice 2000/3000
 dtmf-relay rtp-nte
The thing I don't see - and I don't know why I missed it in the first place - are the SIP bind commands. Everything else looks hunky-dory. Try adding the following. If this doesn't work, we may need to dig into a CUE debug, which I'm hoping we don't have to do:
voice service voip
 sip
 bind all source-interface GigabitEthernet0/0.20
Let us know how it goes.
Maren
Thanks again Maren,
Unfortunately still the same after those modifications. My Debug CCSIP Error shows the following:
*Oct 20 16:27:40.472: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
 Freeing NULL pointer!
SIP: (1207) Attribute mid, level 1 instance 1 not found.
SIP: (1207) setup attribute, level 1 instance 1 not found.
SIP: (1207) connection attribute, level 1 instance 1 not found.
SIP: (1207) Attribute label, level 1 instance 1 not found.
SIP: (1207) a=framerate attribute, level 1 instance 1 not found.
*Oct 20 16:27:40.480: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
 Unexpected VoIPCodec Type :No Codec
SIP: (1208) Group (a= group line) attribute, level 65535 instance 1 not found.
*Oct 20 16:27:40.488: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
 No entry found in reg Number Table for 101
VIGCME#
 No entry found in reg Number Table for 2000
*Oct 20 16:27:40.488: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
 ReqLine IP addr does not match with host IP addr
SIP: Attribute mid, level 1 instance 1 not found.
SIP: setup attribute, level 1 instance 1 not found.
SIP: connection attribute, level 1 instance 1 not found.
SIP: Attribute label, level 1 instance 1 not found.
SIP: a=framerate attribute, level 1 instance 1 not found.
*Oct 20 16:27:40.496: //1208/7AABEEB98320/SIP/Error/sipSPIGetNewLocalMediaDirection:
 Unknown media direction (0) from remote end
VIGCME#
*Oct 20 16:27:44.648: //1208/7AABEEB98320/SIP/Error/sipSPIFlushDeferredQueue:
VIGCME#
*Oct 20 16:28:05.392: //1202/753EC660831F/SIP/Error/sipSPIFlushDeferredQueue:
VIGCME#
*Oct 20 16:28:09.356: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table:
 No entry found in sipCallID Table
*Oct 20 16:28:09.356: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
*Oct 20 16:28:09.356: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag:
 Unable to access supported header values
*Oct 20 16:28:09.856: //1209/8BE348508327/SIP/Error/ccsip_spi_register_incoming_registration:
 Registration Authorization failed with authorization header=
*Oct 20 16:28:09.856: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper:
 Null ContentQ - Exit
*Oct 20 16:28:09.856: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_rpcb_search_cc_call_id_table:
 No entry found in ccCallID Table
*Oct 20 16:28:09.860: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table:
*Oct 20 16:28:09.860: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
*Oct 20 16:28:09.860: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag:
*Oct 20 16:28:10.364: //1209/8BE348508327/SIP/Error/ccsip_spi_register_incoming_registration:
 Registration Authorization failed with authorization header=Digest username="", realm="", nonce="A898C107015EC814", qop=auth, cnonce="gzvXlbKPk5PIsx6", nc=00000001, uri="sip:192.168.30.1:5060", response="2f4b060852eab6d00a757c20da892126", algorithm=MD5
*Oct 20 16:28:10.364: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper:
Not Sure if this helps at all.
I'm not sure what is registering there. It's possible the bind commands are requiring a reset of SIP on the router. Try this to see if the registration errors stop.
voice service voip
 sip
  call service stop
  no call service stop
In the original debug ccsip messages it shows that the phone is sending RTP to the router and the router is sending RTP to CUE. But CUE is not sending RTP back. (That is shown in the P-RTP-Stat line in the BYE/OK messages.) So I believe the problem is in CUE. What is the licensing status in CUE? If you can get to the CUE GUI, what does it show for system/license/etc. status?
Maren
Hi Maren,
The registration failure is actually a Polycom conference phone I was testing but all good, you can ignore that.
The license and system info is as follows for CUE
VIG-CUE# sh software licenses
Installed license files:
 - voicemail_lic.sig : 250 MAILBOX LICENSE
 - ivr_lic.sig : 8 PORT IVR BASE LICENSE
Core:
 - Application mode: CCME
 - Total usable system ports: 24
Voicemail/Auto Attendant:
 - Max system mailbox capacity time: 18000
 - Default # of general delivery mailboxes: 25
 - Default # of personal mailboxes: 250
 - Max # of configurable mailboxes: 275
Interactive Voice Response:
 - Max # of IVR sessions: 8
Languages:
 - Max installed languages: 5
 - Max enabled languages: 5
VIG-CUE# show software packages
Installed Packages:
 - Installer (Installer application) (7.0.6.0)
 - Thirdparty (Service Engine Thirdparty Code) (7.0.6)
 - Bootloader (Primary) (Service Engine Bootloader) (2.1.14)
 - Infrastructure (Service Engine Infrastructure) (7.0.6)
 - Global (Global manifest) (7.0.6)
 - Service Engine license (License for the Service Engine) (2.1.2.0)
 - Auto Attendant (Service Engine Telephony Infrastructure) (7.0.6)
 - Voice Mail (Voicemail application) (7.0.6)
 - Bootloader (Secondary) (Service Engine Bootloader) (2.1.14.0)
 - Core (Service Engine OS Core) (7.0.6)
 - GPL Infrastructure (Service Engine GPL Infrastructure) (7.0.6)
Installed Plug-ins:
 - CUE Voicemail Language Support (Languages global pack) (7.0.6)
 - CUE Voicemail Latin American Spanish (Latin American Spanish language pack) (7.0.6)
 - CUE Voicemail US English (English language pack) (7.0.6)
VIG-CUE# sh tech-su
------------------ show interfaces ------------------
GigabitEthernet 0 is up, line protocol is up
  Internet address is 192.168.30.5 mask 255.255.255.0 (configured on router)
     16097 packets input, 1795496 bytes
     0 input errors, 0 dropped, 0 overrun, 0 frame errors
     16869 packets output, 2369254 bytes
     0 output errors, 0 dropped, 0 overrun, 0 collision errors
     0 output carrier detect errors
GigabitEthernet 1 is up, line protocol is down
     0 packets input, 0 bytes
     0 packets output, 0 bytes
IDE hd0 is up, line protocol is up
     7242 reads, 126507008 bytes
     0 read errors
     3208 write, 44122112 bytes
     0 write errors
------------------ show java version ------------------
java version "J2ME Foundation Specification v1.1"
IBM J9 2.3 Linux x86-32  (JIT enabled)
J9VM - 20061023_08962_lHdFGQ
JIT  - 20060629_1804ifx1_r8
GC   - 200609_15
JCL  - 20070212_2313,foun11
Licensed Materials - Property of IBM
J9 - VM for the Java(TM) platform, Version 2.3
(c) Copyright IBM Corp. 1991, 2006  All Rights Reserved
Target: 20061023_08962_lHdFGQ (Linux 2.6.11.11cisco x86)
IBM is a registered trademark of IBM Corp.
Java and all Java-based marks and logos are trademarks or registered
trademarks of Sun Microsystems, Inc.
Apgee Delivery ID: "2008.May.30.j9231.foun11.j14.x86.lnx.tar.gz"
                   "2008.May.30.classpath090.j9231.foun11.x86.lnx.tar.gz"
------------------ show memory ------------------
SDRAM (MByte):                512
Total Memory (kB):            512312
Active Memory (kB):           269160
Inactive Memory (kB):         36648
Other Memory (kB):            24380
MemoryPool (kB):              182124
Kernel Memory
MAXUSED(S) INUSE(S) INUSE(O) MAXUSED(O)     ERR TYPE
      4252     4184     4027       4107       0 fs
     14532    14108    13244      13749       0 other
       308      240      201        282       0 net
S - Slab memory
O - Object memory
------------------ show processes memory ------------------
   VSZ   RSS   SHR   PVT    RD    RW   EXE   DAT   STK  %PVT CMD
 12728  1428  1040   388     0     0   100  2784     0   0.1 syslog-ng
 22756  1440  1152   288     0     0    64 12832     0   0.1 platform_config
 10432  1188   996   192     0     0    28   540     0   0.0 rbcp
 16372  2600  1276  1324     0     0    20  4656     0   0.3 trace
  2564  1220  1008   212     0     0   572   468     0   0.0 monitor
 18892  1440  1164   276     0     0   216  8808     0   0.1 ntp
 23556  3844  1484  2360     0     0    20 11840     0   0.5 downloader
 10388  1124   960   164     0     0    12   536     0   0.0 probe
 16664     0     0     0     0     0     0     0     0   0.0 sql
 18004  4028  2656  1372     0     0    80  6004     0   0.3 ldap
 82176 46076  3504 42572     0     0    44 68216     0   8.3 http
 82176 46076  3504 42572     0     0    44 68216     0   8.3 mgmt
 82176 46076  3504 42572     0     0    44 68216     0   8.3 snmp
 75948 39776  3136 36640     0     0    44 63808     0   7.2 superthread
 75948 39776  3136 36640     0     0    44 63808     0   7.2 entitymanager
 75948 39776  3136 36640     0     0    44 63808     0   7.2 SubsystemEditorExpress
 75948 39776  3136 36640     0     0    44 63808     0   7.2 webapp
 75948 39776  3136 36640     0     0    44 63808     0   7.2 umg-registration
 75948 39776  3136 36640     0     0    44 63808     0   7.2 cli
 75948 39776  3136 36640     0     0    44 63808     0   7.2 umg-directory
 75948 39776  3136 36640     0     0    44 63808     0   7.2 llama
 75948 39776  3136 36640     0     0    44 63808     0   7.2 sitemanager
 96352 54588  2728 51860     0     0    44 83344     0  10.1 ccn
 75948 39776  3136 36640     0     0    44 63808     0   7.2 usermanager2
 82176 46076  3504 42572     0     0    44 68216     0   8.3 imap
Give a try with the call service stop/no call service stop commands to reset the SIP UA after the bind to see if that fixes things.
If not, I am out of ideas. I do think the issue is in CUE, but I am not skilled at reading CUE trace files. It might be time to call TAC for assistance.
Maren
Luc Boudreau
Thanks Maren,
I realized the dial-peer creation for the DNs after I had already posted my comment. Guess I didn't have enough coffee this morning.
Attached are the two debugs.
Steven L
Try adding "supplementary-service media-renego" under voice service voip and then test
That did not work unfortunately. Still no audio. The call connects but just dead air. The CCSIP Error debug shows "No Codec" on some lines. Very odd issue. First time i've run into it.
