Cisco ATA 191 not registering on cucm
akram.root
Level 4
Level 4
Hello ,
I have a ATA 191 registered already on cucm 11.5 all work fine but after this ATA not registering on cucm , i had reset it and reconfigure it
but not success , it give me his addrress IP and i can enter to it by browser and i can't modified anything ,just reading his configuration parameters , when i check the logs i found this:
local1.err Telephony: CUCM ERROR!!! [cucm_load_info: 285(tick=0x0)]load domain name fails
ATA191 local1.err Telephony: CUCM ERROR!!! [cucm_load_info: 304(tick=0x0)]load tftp address fails
Could you help me to redister this ATA on CUCM again ?
Best regards
18 Replies 18
MrButton
Do you have any ATAs registered in CUCM?  If yes do a settings comparison.  If everything looks good in the profile and Device security Profile under Protocol Specific Information make sure your DHCP is sending OPTION 150 with the TFTP server addresses.
Thank you for your reply,
 Do you have any ATAs registered in CUCM? Yes , i had alreday do a settings comparaison ,all have the same configuration.
My DHCP is sending correcttely the option 150 with the  tftp server address.
The problem is solved after configure  TFTP server address manually via IVR.
For IVR, hit ****
Enter password, default is 24726
Enter option 221 to configure TFTP server IP address
Best regards
