Cisco Attendant Console - Not User Friendly & Not Smart
Chi Fai Leung
The user always complain the Attendant Console interface and layout is not user friendly and is not smart. How can I improve the interface to be more
beautiful and make the make some layout are bigger or hidden some layout?
Actually, some icons are mismatch the related functions, e.g. the MUTE icon matched the HOLD function. Why?
My AC version is enterprise 8.6 with CM 7.1.3
Manish Gogna
Hi Chi Fai,
You can try the options listed under the 'Display' section of the following link for CUEAC 8.6
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUEACUGv8_6_x.pdf
You can also play with the resolution of the PC hosting CUEAC to adjust the font apart from the three font size options available.
Manish
Typical complain.
Have a look at another console, we have developed to get the nice to see and use effect:
http://www.imagicle.com/go/bluesattendant
You can also find info on Cisco Solutions catalog.
Regards.
Chris
