09-29-2015 08:46 PM - edited 03-19-2019 10:09 AM
Just want to ask what services that needs to be restarted for CUCM and Unity Connection if cannot hear prompts when calling Unity Connection Voicemail. Thanks.
Arvie
09-29-2015 09:01 PM
Try the conversation manager
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/serv_administration/guide/10xcucservagx/10xcucservag040.html
09-29-2015 09:04 PM
Hi Jaime,
Thanks for the response. I've already restarted Unity Connection but still the same.
Arvie
09-29-2015 09:19 PM
Are the services running?? Can you hear the greetings via the CUC admin???
What happened before this started??
09-29-2015 10:33 PM
Yes, the services are all running. Actually the CUCM is already running, I just installed Unity Connection for MeetMe purposes but when I tried to test my integration (SCCP) I cannot hear the voicemail prompt. I am also connected to the voicemail system.
09-30-2015 04:25 AM
since its a new installation i think the integration is not done properly.
On SCCP integration, CUCM connects to unity connection via VM ports and these ports are typically arranged in a huntgroup when you configure it.
review the configuration again and check if all the VM ports are registered to cucm.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/integration/guide/cucm_sccp/cucintcucmskinny/cucintcucmskinny070.html
also if you are testing it on a subscriber level, then make sure the VM profile is selected for that subscriber and what do you hear on dialing a VM pilot number ?
