Cisco CVP IVR Integration with SOAP Webservice Unified Communcation
ashik.buhari
Hi All,
Iam trying to integrate IVR application with SOAP webservice,but getting response code 500 and error response as below.
Please advise where I need to correct
Http response code from the host==>>>500
Error Reseponse Received::::<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><s:Fault><faultcode xmlns:a="http://schemas.microsoft.com/ws/2005/05/addressing/none">a:ActionNotSupported</faultcode><faultstring xml:lang="en-US">The message with Action '' cannot be processed at the receiver due to a ContractFilter mismatch at the EndpointDispatcher. This may be because of either a contract mismatch (mismatched Actions between sender and receiver) or a binding/security mismatch between the sender and the receiver. Check that sender and receiver have the same contract and the same binding (including security requirements e.g. Message Transport None).</faultstring></s:Fault></s:Body></s:Envelope>
b.winter
Why don't you post your question to the DevNet forum?
https://community.cisco.com/t5/developer-collaboration/ct-p/j-developer-collab
