12-14-2007 05:46 AM - edited 03-18-2019 08:13 PM
Hi all,
Some questions about Cisco IP Communicator Software:
- What do you think about this Software?
- Does it support 802.1q? I think that I need a NIC card working with 802.1q. Is it correct?
Thats a lot.
12-14-2007 06:40 AM
IP Communicator is very nice. Depending on your situation, it can be very beneficial - mobile employees, etc. IP Communicator does not support 802.1q natively.
Hope this helps. If so, please rate the post.
Brandon
12-14-2007 06:53 AM
Hi Brandon,
When you said "Natively" there is some add-one? or all Voice trafic will be in Data Trafic.
Currently I have 2 Vlans, one data and one voice and using Auto-Qos.
What happen with this Software? All trafic in my Data Vlan?
I read that DSCP is supporting but no information about Vlans..
Thanks a lot again for your answer
12-14-2007 07:11 AM
There is no add on. All voice traffic from IPC will be in the data VLAN. Take a look at the following section of the QoS SRND linked below.
Campus QoS Design -> Catalyst 2970/3560/3750 - Untrusted PC + Softphone with Scavenger-Class QoS Model
QoS SRND
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
As also mentioned in this document, you can use the "auto qos voip cisco-softphone" command to generate a baseline QoS config that will take the softphone into account.
Brandon
12-14-2007 07:38 AM
Great Brandon. Thank a lot
07-30-2010 07:28 AM
Hi Brandon,
Is it already the same behaviour for Cisco IP Communicator with CUCM 7.1 ?
Because I would like to separate the voice and data trafic. Is it possible ?
When I tested 2 VLANs on my computer (Voice Vlan Tagged, Data Vlan native), the IP Communicator registered on CUCM with IP Address of Voice VLAN, but when I do a traces on my PC, I see communication between IP Address of Data VLAN and IP Address of CUCM.
So what is the solution ?
For information, the switch is not a catalyst, but a Nortel swith.
Davy
07-30-2010 07:34 AM
It could be that signaling is using the voice VLAN and RTP (audio) traffic is using the data VLAN. Check the setting in IPC under Preferences > Audio > Network > Audio IP Address.
Hope this helps.
Brandon
07-30-2010 07:41 AM
No the signaling message (SCCP) is using the voice VLAN.
I didn't test audio message (RTP).
But you said before in the post (3. 14 déc. 2007 08:11 En réponse à: fargier ) that all voice traffic from IPC will be in the data VLAN.
So maybe is it normal ?
Davy
07-30-2010 07:42 AM
Sorry No the signaling message (SCCP) is using the Data VLAN !
07-30-2010 07:44 AM
Signaling is using the data VLAN, but the IPC is registered with CUCM with the voice VLAN IP address? Seems strange.
07-30-2010 07:50 AM
Yes exactly.
Since I have 2 Vlans on my computer, when I do a "route print" on windows, I have 2 routes 0.0.0.0
One for Voice VLAN and one for Data VLAN
I changed metric for Data VLAN in order to have Data VLAN as the default Gateway for my computer.
Even if I add a specific route to the CUCM network, I have a communication between Data Vlan and CUCM.
What is the best implementation of IPC in order to separate Voice and Data trafic ? Is it possible ?
Did you already realize this kind of configuration with IPC ?
Thanks.
Davy
07-30-2010 07:55 AM
Did you check the setting I mentioned above?
07-30-2010 08:06 AM
Yes it is good, I have mentionned the right nic associated to voice vlan
07-30-2010 08:11 AM
What happens if you shut down the NIC in the data VLAN? Does IPC register/function properly on the voice VLAN?
07-30-2010 08:13 AM
If shut down the NIC in the data VLAN, then the registering on CUCM is the same, but in this case IPC function properly on the Voice Vlan.
