- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-31-2013 11:57 PM - edited 03-19-2019 06:30 AM
Hello ,
my issue is when i try to register cisco jabber for android, it is registered successful but after some moment its disconnected by itself and shown as unregister .
again i try to reset the device on call manager but same issue registered and disconnect .
i try to register the folowing devices:
Galaxy S3
Galaxy S2
Galaxy note I
and we face same issue
for cucm configuration, I've installed cop files, restarted publisher and subscriber, and also tomcat service.
and changing all values was suggest on the below documentation :
is there any solution for my issue ??
Please i need your help ....
Solved! Go to Solution.
- Labels:
UC Applications
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-12-2013 10:35 AM
Hello Ahmed.
I have a Galaxy S2 with android 4.0.3
I used this guide to configurate jabber with my call manager 9.1
I had problem with the registration of the jabber client on my android
firstly (jabber with iphone worked fine) but I fixed it configuring in the jabber client the option the corporate wireless.
You can do the following en the jabber client:
Go into the cisco jabber, then --> Configuration --> Wifi corporate --> Default wifi --> then here you select your wifi access
I hope that this work with you.
Max
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-01-2013 03:03 AM
HI
Kindly find the below steps to troubleshoot :-
1- Make sure that you attach to your Android the new SIP profile..
2-Check on your wireless access point , the routing is ok to your CCM.
3-The last thing reboot your cluster.
Note ; be sure that you select the dual mode for Android
If it is not working , please share the version of your Android
Thank you
please rate if this will help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 12:08 AM
Hi islam.kamal
first thanks for kindly reply ,,,
i make sure i did all steps you mention above , but still not working .
android version is 4.1.2 .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 02:01 AM
Dear
try the below
- Enter the IP address instead of the hostname of the Cisco Unified Communications Manager server into the TFTP Server Address setting in Cisco Jabber.
- If the value in System > Server in Cisco Unified Communications Manager is a hostname without a domain, enter your domain name in the Domain Name field in the Cisco Dual Mode for Android device page.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 03:36 AM
Sorry to be the bearer of bad news.
The Jabber for Android client is very poor and simply doesn't work on most of the devices I have tested with. It seems to be Android version and hardware specific. I have an HTC Desire S when the client worked fine on version 2.3, however as soon as I upgraded to ICS I get the same issue as you. Jabber will sometimes register, mostly not. Even when registered, if I place a call I get no audio. Network captures show communication between client and CUCM so it's not host / DNS name related.
The forums are full of other users with the same kinds of problems. Check out the app reviews and you'll see what I mean.
I suggest you try CSIPSimple instead. I installed and configured it in 5 minutes and it works perfectly even on platforms where JFA doesn't work.
Barry Hesk
Intrinsic Network Solutions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 03:55 AM
HI islam.kamal
i have already put IP not hostname on the setting in Cisco Jabber.and also i put the domain name on Cisco Dual Mode for Android device page it was not configured
for now it is register i will wait to the end of the day if is it will disconnect or not .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 04:04 AM
HI barry
what do you mean by CSIPSimple is it application or what ??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 05:09 AM
Dear
As barry said , the best version which is used and it is ok v2.3 . Any way try and waiting your feedback.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 05:58 AM
Hi Islam.kamal
still now it is register ,
i think the issue was resolved by adding the domain name anyway i will keep
monitoring the connection during this week .
again many thanks to your support .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-02-2013 07:15 AM
Dear
please rate , if this will work to help other who have other issue.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-03-2013 02:00 AM
HI
i am sadness ,
the issue come back again notregister ,even i change every thing evrything was recommended .
again any suggestion .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-03-2013 04:58 AM
i am so sad to hear that , but i hope to tell you that you are so lucky that is registered for some time because other persons not register . Please i need to use the below link and contact with Cisco (open case) and ask about the solution
http://www.cisco.com/web/partners/tools/pdihd.html
Please share the answer
Thank you
please rate if thi will help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-03-2013 05:33 AM
Hi islam ,
i will do ,
i hope to get solution .
sure i will share the answer if i get it .
again many thanks to your effort with me .
Ahmed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-05-2013 01:11 AM
Hi Ahmed
CSIPSimple is another Android SIP client available on the Play Store. Works great with CUCM 8.6 which proves (to me anyway) that all of the issues are within Jabber for Android. Cisco don't seem very interested in fixing them unfortunately which is a shame.
Barry Hesk
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-12-2013 10:35 AM
Hello Ahmed.
Max
