10-23-2014 06:21 AM
Hi I am trying to create a FTP backup with Cisco Prime Collaboration Version 9.5.34267
I set a backup job in the GUI. I attached the config via screenshot. The Prime contacts the ftp server (test in backup job was fine) and after loggin in it quits...
This is the log of the Filezilla FTP:
(000013)23.10.2014 15:08:26 - (not logged in) (10.48.207.85)> Connected on port 21, sending welcome message...
(000013)23.10.2014 15:08:26 - (not logged in) (10.48.207.85)> 220-FileZilla Server version 0.9.47 beta
(000013)23.10.2014 15:08:26 - (not logged in) (10.48.207.85)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(000013)23.10.2014 15:08:26 - (not logged in) (10.48.207.85)> 220 Please visit https://filezilla-project.org/
(000013)23.10.2014 15:08:26 - (not logged in) (10.48.207.85)> USER test
(000013)23.10.2014 15:08:26 - (not logged in) (10.48.207.85)> 331 Password required for test
(000013)23.10.2014 15:08:26 - (not logged in) (10.48.207.85)> PASS ****
(000013)23.10.2014 15:08:26 - test (10.48.207.85)> 230 Logged on
(000013)23.10.2014 15:08:26 - test (10.48.207.85)> QUIT
(000013)23.10.2014 15:08:26 - test (10.48.207.85)> 221 Goodbye
(000013)23.10.2014 15:08:26 - test (10.48.207.85)> disconnected.
(000014)23.10.2014 15:12:47 - (not logged in) (10.48.207.85)> Connected on port 21, sending welcome message...
(000014)23.10.2014 15:12:47 - (not logged in) (10.48.207.85)> 220-FileZilla Server version 0.9.47 beta
(000014)23.10.2014 15:12:47 - (not logged in) (10.48.207.85)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(000014)23.10.2014 15:12:47 - (not logged in) (10.48.207.85)> 220 Please visit https://filezilla-project.org/
(000014)23.10.2014 15:12:47 - (not logged in) (10.48.207.85)> USER test
(000014)23.10.2014 15:12:47 - (not logged in) (10.48.207.85)> 331 Password required for test
(000014)23.10.2014 15:12:47 - (not logged in) (10.48.207.85)> PASS ****
(000014)23.10.2014 15:12:47 - test (10.48.207.85)> 230 Logged on
(000014)23.10.2014 15:12:47 - test (10.48.207.85)> DELE /temp/transfer/assurance_Thu_Oct_23_15_08_25_CEST_2014.tar.gpg
(000014)23.10.2014 15:12:47 - test (10.48.207.85)> 550 File not found
(000014)23.10.2014 15:12:47 - test (10.48.207.85)> QUIT
(000014)23.10.2014 15:12:47 - test (10.48.207.85)> 221 Goodbye
(000014)23.10.2014 15:12:47 - test (10.48.207.85)> disconnected.
Where is the problem? Target path is c:\temp\transfer
Many thanks
10-23-2014 07:06 AM
Hi ,
seems path is incorrect.
Did u create repository ?Please follow the below steps and link
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/9-0/administration/guide/PC9-0AdminGuide/backupandrestore.html
You must create a repository before backing up the data. By default, the backup service creates a *.tar.gpg file under the configured repository. The backed-up file is in a compressed format. The repository can be on CD-ROM, disk, HTTP, FTP, SFTP, or TFTP.
To create a repository:
Step 1 Log in to the Prime Collaboration Assurance server with the account that you created during installation. The default login is admin.
Step 2 Enter the following commands to create a repository on a disk:
admin#
config t
admin(config)# repository RepositoryName
admin(config-Repository)# url ftp://ftpserver/directory
admin(config-Repository)# user UserName password {plain | hash} Password
admin(config-Repository)# exit
admin(config)# exit
Where:
•RepositoryName is the location to which files should be backed up. This name can contain a maximum of 30 alphanumeric characters.
•ftp://ftpserver/directory is the FTP server and the directory on the server to which the file is transferred. You can also use SFTP, HTTP, disk, or TFTP instead of FTP.
•UserName and {plain | hash} Password are the username and password for the FTP, SFTP, or TFTP server. hash specifies an encrypted password, and plain specifies an unencrypted plain text password.
For example:
admin#
config t
admin(config)# repository tmp
admin(config-Repository)# url ftp://ftp.cisco.com/incoming
admin(config-Repository)# user john password plain john!23
admin(config)# exit
After creating the repository, Log in to the Prime Collaboration Assurance server as admin and run the following command to back up the data:
admin#
backup Backupfilename repository RepositoryName application cpcm
Where,
•Backupfilename—Name of the backup file (without the extension-.tar.gpg). This name can be a maximum of 100 alphanumeric characters.
•RepositoryName—Location to which the files are be backed up. This name can contain a maximum of 30 alphanumeric characters.
The following message appears after the backup is complete:
% Creating backup with timestamped filename:
Backupfilename-Timestamp.tar.gpg
The backup file is suffixed with the time stamp (YYMMDD-HHMM) and file extension .tar.gpg and saved in the repository. For example:
admin# backup cmbackup repository tmp application cpcm
% Creating backup with timestamped filename: cmbackup-110218-0954.tar.gpg
regds,
aman
10-23-2014 07:27 AM
I did this by these commands:
servername/admin# conf t
Enter configuration commands, one per line. End with CNTL/Z.
servername/admin(config)# repository backuptest
servername/admin(config-Repository)# url ftp://10.48.67.24/temp/transfer
servername/admin(config-Repository)# user test password plain test
servername/admin(config-Repository)# exit
servername/admin(config)# exit
But it still doesn´t work.
10-23-2014 09:17 AM
can u try using freeftpd software sftp by creating a folder in C:\backup ?
admin/admin(config)# repository PrimeBackupNew
admin/admin(config-Repository)# url sftp://172.19.57.36 [ IP of PC on which sftp software is working]
admin/admin(config-Repository)# user test password plain test
admin/admin(config-Repository)# exit
admin/admin(config)# exit
admin/admin# backup prime repository PrimeBackupNew application cpcm
What is the backup command u are using ? I still doubt there is a problem in path.
regds,
aman
10-24-2014 02:00 AM
This is my command:
PFM1EU-TEL70/admin(config)# repository PrimeBackupNew
PFM1EU-TEL70/admin(config-Repository)# url sftp://10.48.67.24
PFM1EU-TEL70/admin(config-Repository)# user test password plain test
PFM1EU-TEL70/admin(config-Repository)# exit
PFM1EU-TEL70/admin(config)# exit
PFM1EU-TEL70/admin# backup prime repository PrimeBackupNew application cpcm
% Creating backup with timestamped filename: prime-141024-1022.tar.gpg
arg0=/opt/emms/emsam/bin/cpcmbackup.sh, arg1=/opt/backup/backup-prime-141024-1022-1414138960/backup/appcomponent, arg2=, arg3=
Export: Release 11.2.0.2.0 - Production on Fri Oct 24 10:22:42 2014
Copyright (c) 1982, 2009, Oracle and/or its affiliates. All rights reserved.
Connected to: Oracle Database 11g Enterprise Edition Release 11.2.0.2.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
Export done in US7ASCII character set and AL16UTF16 NCHAR character set
server uses WE8MSWIN1252 character set (possible charset conversion)
About to export specified users ...
. exporting pre-schema procedural objects and actions
. exporting foreign function library names for user CMUSER
. exporting PUBLIC type synonyms
. exporting private type synonyms
. exporting object type definitions for user CMUSER
About to export CMUSER's objects ...
. exporting database links
. exporting sequence numbers
. exporting cluster definitions
. about to export CMUSER's tables via Conventional Path ...
. . exporting table ACLAPPLIEDTOPEP 0 rows exported
. . exporting table ALARM 0 rows exported
. . exporting table ALARMNOTE 0 rows exported
. . exporting table ALARMSET 2 rows exported
. . exporting table ALARMSETCODEMAPPING 253 rows exported
. . exporting table APPLICATIONVERSION 0 rows exported
. . exporting table APPLICATIONVERSIONHISTORY 0 rows exported
. . exporting table ASSURANCEDOMAIN 5 rows exported
. . exporting table AUDITLOG 0 rows exported
. . exporting table AUTHORITIES 29 rows exported
. . exporting table AUTH_PROVIDER_CONFIG 0 rows exported
. . exporting table BASEENTITY 3442 rows exported
. . exporting table BASEENTITY_PROPS 7546 rows exported
. . exporting table BGPADJACENCY 0 rows exported
. . exporting table BGPNEIGHBORSTATEINFO 0 rows exported
. . exporting table BGPPROCESSSETTINGS 0 rows exported
. . exporting table CALLDETAILRECORD 0 rows exported
. . exporting table CALLQUALITYRCARESULT 0 rows exported
. . exporting table CALLQUALITYRCARUN 0 rows exported
. . exporting table CALLQUALITYRCASTATUS 0 rows exported
. . exporting table CALLQUALITYRCATEST 25 rows exported
. . exporting table CAMERA 0 rows exported
. . exporting table CDPNEIGHBORINFO 0 rows exported
. . exporting table CHRCTRSTCS10_PROTOCOLNAME 0 rows exported
. . exporting table CHRCTRSTCS7_DSTADDRESS 0 rows exported
. . exporting table CHRCTRSTCS7_PSSNGRPRTCL 0 rows exported
. . exporting table CHRCTRSTCS7_SRCADDRESS 0 rows exported
. . exporting table CMBACKUPSETTINGS 4 rows exported
. . exporting table CMCLSTR 0 rows exported
. . exporting table CMCOMPOSITEREPORTS 0 rows exported
. . exporting table CMCOMPOSITEREPORTS_PROPS 0 rows exported
. . exporting table CMCTXROUTE 0 rows exported
. . exporting table CMDEVICE 3442 rows exported
. . exporting table CMDEVICEREGIONMAPPING 0 rows exported
. . exporting table CMJOB 0 rows exported
. . exporting table CMJOBITEM 0 rows exported
. . exporting table CMJOBPROGRESS 0 rows exported
. . exporting table CMJOBRESULT 0 rows exported
. . exporting table CMJOBSPECPROGRESS 60 rows exported
. . exporting table CMLINK 0 rows exported
. . exporting table CMPATH 0 rows exported
. . exporting table CMPATHHOPS 0 rows exported
. . exporting table CMPNDCNDTNHSPLCYCNDTNS 0 rows exported
. . exporting table CMREGION 0 rows exported
. . exporting table CMREPORTSETTINGS 8 rows exported
. . exporting table CMRESOURCEGROUP 0 rows exported
. . exporting table CMROUTERSWITCHINFO 0 rows exported
. . exporting table CMSERVICEPROVIDER 0 rows exported
. . exporting table CMSIMPLEREPORTSETTINGS 0 rows exported
. . exporting table CMSIMPLEREPORTSETTINGS_PROPS 0 rows exported
. . exporting table CNEXPOSESPEPS 0 rows exported
. . exporting table CNHASINTERNALPEPS 0 rows exported
. . exporting table COMMSERVERCLUSTER 0 rows exported
. . exporting table COMMUNICATIONSSERVER 3 rows exported
. . exporting table COMPOUNDACTIONHASPOLICYACTIONS 0 rows exported
. . exporting table CONFIG_OBJECT_TRACKER 0 rows exported
. . exporting table CONNECTIVITYNETWORK 0 rows exported
. . exporting table CONNECTIVITYNETWORKHASFRS 0 rows exported
. . exporting table CONTACTDETAILS 0 rows exported
. . exporting table CREDENTIAL 0 rows exported
. . exporting table CTSSTATSCPU 0 rows exported
. . exporting table CTSSTATSMEMORY 0 rows exported
. . exporting table CTXCLUSTERDATA 0 rows exported
. . exporting table CTXCLUSTERNODESTATE 0 rows exported
. . exporting table CTXREGIONUTILSTATS 0 rows exported
. . exporting table CTXRESOURCESTATS 0 rows exported
. . exporting table CTXRESOURCEUTILSTATS 0 rows exported
. . exporting table CUCMCDR 0 rows exported
. . exporting table CUCMRTMTTHRESHOLDS 7 rows exported
. . exporting table DEPENDANTLINKRELATESLTPS 0 rows exported
. . exporting table DEVICE 0 rows exported
. . exporting table DEVICEACCESSCREDENTIAL 14 rows exported
. . exporting table DEVICEACCESSCREDENTIAL_MAP 92 rows exported
. . exporting table DEVICEACCESSPROFILE 7 rows exported
. . exporting table DEVICEACCESSPROFILE_MAP 37 rows exported
. . exporting table DEVICEEVENTCONFIG 0 rows exported
. . exporting table DEVICEEVENTCONFIGURATION 0 rows exported
. . exporting table DICTIONARY 40 rows exported
. . exporting table DISCOVEREDVIAPEP 0 rows exported
. . exporting table DISPLAY 0 rows exported
. . exporting table DJCNCY3_NCY5_LNKSPPRTDBYFR3 0 rows exported
. . exporting table DJCNCY3_U_DPNDNTLNKRLTSLTPS7 0 rows exported
. . exporting table DJCNCY4_NCY5_LNKSPPRTDBYFR3 0 rows exported
. . exporting table DJCNCY4_U_DPNDNTLNKRLTSLTPS7 0 rows exported
. . exporting table DJCNCY5_DPNDNTLNKRLTSLTPS 0 rows exported
. . exporting table DJCNCY5_LINKSUPPORTEDBYFR 0 rows exported
. . exporting table DJCNCY5_NCY5_LNKSPPRTDBYFR3 0 rows exported
. . exporting table DJCNCY5_U_DPNDNTLNKRLTSLTPS7 0 rows exported
. . exporting table DMM_CHANGENOTIFICATIONCONFIG 0 rows exported
. . exporting table DMM_DYNAMICGROUPRULE 0 rows exported
. . exporting table DMM_EXCLUDEASSOCIATION 0 rows exported
. . exporting table DMM_GROUP 0 rows exported
. . exporting table DMM_GROUPINGROUP 0 rows exported
. . exporting table DMM_GROUPMEMBERS 0 rows exported
. . exporting table DMM_GROUPNOTIFICATIONTASK 0 rows exported
. . exporting table DMM_MODELCLASS 483 rows exported
. . exporting table DMM_NOTIFICATIONBINDING 0 rows exported
. . exporting table DMM_PRIVILEGE 0 rows exported
. . exporting table DMM_PRUNESTATUS 0 rows exported
. . exporting table DMM_PRUNINGSERVICEDATA 0 rows exported
. . exporting table DMM_REPORT 0 rows exported
. . exporting table DMM_REPORTDATA 0 rows exported
. . exporting table DMM_REPORTDEFINITION 0 rows exported
. . exporting table DMM_RETRIEVALSPEC 0 rows exported
. . exporting table DMM_RETRIEVALSPECPROPERTIES 0 rows exported
. . exporting table DMM_ROLE 0 rows exported
. . exporting table DMM_ROLEGROUP 0 rows exported
. . exporting table DMM_ROLE_PRIVILEGE 0 rows exported
. . exporting table DMM_SYNCGROUPMEMBERTYPE 0 rows exported
. . exporting table DMM_TRANSACTIONALQUEUE
. . exporting partition PARTITION_0 1833651 rows exported
. . exporting partition PARTITION_1 3180996 rows exported
. . exporting partition PARTITION_2 1919197 rows exported
. . exporting partition PARTITION_3 3186350 rows exported
. . exporting partition PARTITION_4 1768849 rows exported
. . exporting partition PARTITION_5 6765965 rows exported
. . exporting partition PARTITION_6 1812452 rows exported
. . exporting partition PARTITION_7 3179884 rows exported
. . exporting partition PARTITION_8 1919512 rows exported
. . exporting partition PARTITION_9 3187226 rows exported
. . exporting partition PARTITION_10 1769187 rows exported
. . exporting partition PARTITION_11 6759413 rows exported
. . exporting table DMM_TRXQUEUESCANPOSITION 2 rows exported
. . exporting table DNGPTH4_CNNCTVTYNTWRKHSFRS 0 rows exported
. . exporting table DPNDNTLNKTYPSCNRLTLTPTYPS 0 rows exported
. . exporting table EIGRPADJACENCY 0 rows exported
. . exporting table EIGRPPEPSETTINGS 0 rows exported
. . exporting table EIGRPPEPSTATISTICS 0 rows exported
. . exporting table EIGRPPROCESSSETTINGS 0 rows exported
. . exporting table EIGRPPROCESSSTATISTICS 0 rows exported
. . exporting table EMSAMAUTHORITY 0 rows exported
. . exporting table EMSAMUSER 0 rows exported
. . exporting table EQUIPMENT 0 rows exported
. . exporting table EQUIPMENT_POSITION 0 rows exported
. . exporting table ETHERNETPROTOCOLENDPOINT 9 rows exported
. . exporting table ETHRNTPRTCLENDPNTEXTNDD 0 rows exported
. . exporting table EVENT 0 rows exported
. . exporting table FAULTALARM 54 rows exported
. . exporting table FAULTALARMNOTE 0 rows exported
. . exporting table FAULTALARM_ACTIVEEVENTS 3 rows exported
. . exporting table FAULTALARM_HISTORICALEVENTS 184 rows exported
. . exporting table FAULTDEPENDENCY 0 rows exported
. . exporting table FAULTEVENT 202 rows exported
. . exporting table FAULTEVENT_PROPS 3586 rows exported
. . exporting table FAULTROLLUP 3 rows exported
. . exporting table FEATUREACTIVEONPEP 0 rows exported
. . exporting table FEATUREAVAILABLETHROUGHLTP 0 rows exported
. . exporting table FEATUREDFUNCTION 0 rows exported
. . exporting table FEATURE_TEMPLATE 0 rows exported
. . exporting table FILESYSTEM 0 rows exported
. . exporting table FILESYSTEMENTRY 0 rows exported
. . exporting table FILESYSTEMSTATISTICS 0 rows exported
. . exporting table FLASHPARTITION 0 rows exported
. . exporting table FLASHSTORAGEDEVICE 0 rows exported
. . exporting table FLOORLAYOUT 0 rows exported
. . exporting table FORWARDINGPATH 0 rows exported
. . exporting table FORWARDINGRELATIONSHIP 0 rows exported
. . exporting table FREND 0 rows exported
. . exporting table FUNCTIONALCAPABILITY 0 rows exported
. . exporting table GEOGRAPHICSUBADDRESS 0 rows exported
. . exporting table GPRTTN3_INTRNLRSRCRLZDBY 0 rows exported
. . exporting table GRT 0 rows exported
. . exporting table GRT_ALTERNATE_KEYS 0 rows exported
. . exporting table HBRINF5_BRINF_NGMNTADDRSS67 0 rows exported
. . exporting table HBRINF5_DISCOVEREDVIAPEP 0 rows exported
. . exporting table HBRINF6_BRINF_NGMNTADDRSS67 0 rows exported
. . exporting table HBRINF6_DISCOVEREDVIAPEP 0 rows exported
. . exporting table HT_BASEENTITY
. . exporting table IMGINSTLLD5_FEATURES 0 rows exported
. . exporting table IMGINSTLLD5_RDWRPLTFRMS5 0 rows exported
. . exporting table INTERFACE 0 rows exported
. . exporting table INTERFACEPROTOCOLENDPOINT 9 rows exported
. . exporting table INTERFACE_IPADDRESSES 0 rows exported
. . exporting table INTRFCPRTCLENDPNTSTTSTCS 0 rows exported
. . exporting table INVENTORYENTITYCACHE 51 rows exported
. . exporting table IPACE_DSTNTNPRT 0 rows exported
. . exporting table IPACE_SOURCEPORT 0 rows exported
. . exporting table IPEPPARTICIPATESINSTPINSTANCE 0 rows exported
. . exporting table IPPROPERTIES 0 rows exported
. . exporting table IPPROTOCOLENDPOINT 6 rows exported
. . exporting table IPSLASESSION 0 rows exported
. . exporting table ISISADJACENCY 0 rows exported
. . exporting table ISISPEPSETTINGS 0 rows exported
. . exporting table ISISPEPSTATISTICS 0 rows exported
. . exporting table ISISPROCESSLEVELSETTINGS 0 rows exported
. . exporting table ISISPROCESSSETTINGS 0 rows exported
. . exporting table ISISPROCESSSTATISTICS 0 rows exported
. . exporting table ISSNGHBRINF_AREAADDRESSES 0 rows exported
. . exporting table JBSPCFCTN_CPBLTYRQRMNTS 0 rows exported
. . exporting table JBSPCFCTN_TINPTPRMTRS3 0 rows exported
. . exporting table JOB 53738 rows exported
. . exporting table JOBSPECBELONGSTOMXGROUP 0 rows exported
. . exporting table JOBSPECIFICATION 107 rows exported
. . exporting table JOBTRIGGER 111 rows exported
. . exporting table JOB_NPTPRMTRS 0 rows exported
. . exporting table JOB_RSLTPRMTRS 0 rows exported
. . exporting table KNOWNNEIGHBORINFO 0 rows exported
. . exporting table KNWNNGHBRINF_NGMNTADDRSS6 0 rows exported
. . exporting table LAG8023ADAGGPORT 0 rows exported
. . exporting table LAG8023ADMEMBERPORTSETTINGS 0 rows exported
. . exporting table LAGBASEAGGPORT 0 rows exported
. . exporting table LCLLCTNRLTVTGLCTN 0 rows exported
. . exporting table LGCLSNSR_INTRNLRSRCRLZDBY 0 rows exported
. . exporting table LICENSEINFO 1 rows exported
. . exporting table LINK 0 rows exported
. . exporting table LINKSPEC 0 rows exported
. . exporting table LINKSUPPORTEDBYFR 0 rows exported
. . exporting table LINKTERMINATIONPOINT 0 rows exported
. . exporting table LINKTERMINATIONPOINTREALIZEDBY 0 rows exported
. . exporting table LINKTERMINATIONPOINTSPEC 0 rows exported
. . exporting table LLDPNEIGHBORINFO 0 rows exported
. . exporting table LOCATION 0 rows exported
. . exporting table LOGICALSENSOR 0 rows exported
. . exporting table LOGICALSENSORSTATISTICS 0 rows exported
. . exporting table LOGICALSENSORTHRESHOLD 0 rows exported
. . exporting table LTPSUPPORTEDBYPEP 0 rows exported
. . exporting table MANAGEDELEMENTINTERFACE 6 rows exported
. . exporting table MANAGEDNETWORKELEMENT 6 rows exported
. . exporting table MANAGEDNETWORKELEMENTLOC 0 rows exported
. . exporting table MANAGEMENTSYSTEM 0 rows exported
. . exporting table MCUBLADE 0 rows exported
. . exporting table MDLROSINSTLLBLACTVTDON 0 rows exported
. . exporting table MEDIAFLOW 0 rows exported
. . exporting table MEDIANODE 0 rows exported
. . exporting table MEDIANODECONNECTION 0 rows exported
. . exporting table MEDIASTREAMINFO 0 rows exported
. . exporting table MEDIATRACESESSION 0 rows exported
. . exporting table MEETING 0 rows exported
. . exporting table MEETING_NATIVE_ID 0 rows exported
. . exporting table MEMORYDEVICE 0 rows exported
. . exporting table MEMORYPOOL 0 rows exported
. . exporting table MEMORYPOOLSTATISTICS 0 rows exported
. . exporting table MICROPHONE 0 rows exported
. . exporting table MMRYDVC_INTRNLRSRCRLZDBY 0 rows exported
. . exporting table MMRYPL_INTRNLRSRCRLZDBY 0 rows exported
. . exporting table MODULAROSINSTALLABLE 0 rows exported
. . exporting table MODULAROSROLLBACKPOINT 0 rows exported
. . exporting table MONTHLYENDPOINTNOSHOW 0 rows exported
. . exporting table MONTHLYENDPOINTUTILIZATION 0 rows exported
. . exporting table MTG_SRC_ND_PRTCPNTS 0 rows exported
. . exporting table MUTUALEXCLUSIONGROUP 0 rows exported
. . exporting table NAMAUTH 0 rows exported
. . exporting table NAMINFO 0 rows exported
. . exporting table NECLIENTCOUNT 0 rows exported
. . exporting table NETWORKRESOURCE 6 rows exported
. . exporting table NETWORKRESOURCECOMPOSEDOF 0 rows exported
. . exporting table NETWORKRESOURCEREALIZEDBY 0 rows exported
. . exporting table NETWORKRESOURCESPEC 0 rows exported
. . exporting table NETWORKVLAN 0 rows exported
. . exporting table NOTIFICATIONPROFILE 1 rows exported
. . exporting table NOTIFICATIONPROFILECATEGFILTER 0 rows exported
. . exporting table NOTIFICATIONPROFILEDESTCNF 0 rows exported
. . exporting table NOTIFICATIONPROFILEDGM 1 rows exported
. . exporting table NOTIFICATIONPROFILETRAPCNF 0 rows exported
. . exporting table NRISCAPABALEOFFUNCTION 0 rows exported
. . exporting table NRMEMBEROFREDUNDANCYSET 0 rows exported
. . exporting table NRPLAYSROLEINREDUNDANCYSET 0 rows exported
. . exporting table NTWRKELMNT4_NTWRKFNCTNS 0 rows exported
. . exporting table NTWRKRSRCEXPSSLNKTRMNTNPNTS 0 rows exported
. . exporting table NTWRKRSRCSPPRTDBYNTWRK 0 rows exported
. . exporting table NTWRKRSRCTYPCNEXPSLTPTYPS 0 rows exported
. . exporting table NUMERICRANGE 0 rows exported
. . exporting table ORDEREDCLASSES 0 rows exported
. . exporting table ORGNZTNUNT_BSNSSCTGRS 0 rows exported
. . exporting table OSPFADJACENCY 0 rows exported
. . exporting table OSPFAREAINFO 0 rows exported
. . exporting table OSPFAREAINFOSTATISTICS 0 rows exported
. . exporting table OSPFAREASTATISTICS 0 rows exported
. . exporting table OSPFPEPSETTINGS 0 rows exported
. . exporting table OSPFPEPSTATISTICS 0 rows exported
. . exporting table OSPFPROCESSSETTINGS 0 rows exported
. . exporting table OSPFPROCESSSTATISTICS 0 rows exported
. . exporting table OSPFVIRTUALLINK 0 rows exported
. . exporting table PAGPMEMBERPORTSETTINGS 0 rows exported
. . exporting table PARAMETER 0 rows exported
. . exporting table PARTY 0 rows exported
. . exporting table PARTYISATLOCATION 0 rows exported
. . exporting table PARTYPLAYSROLEFORNR 0 rows exported
. . exporting table PARTYPLAYSROLESFOREQUIPMENT 0 rows exported
. . exporting table PARTYROLE 0 rows exported
. . exporting table PARTYROLESPEC 0 rows exported
. . exporting table PASSWORDPOLICY 0 rows exported
. . exporting table PATHVIAFRS 0 rows exported
. . exporting table PCDOMAIN 0 rows exported
. . exporting table PCDOMAINCONTACTINFO 0 rows exported
. . exporting table PEPBOUNDTOPEP 0 rows exported
. . exporting table PHONE 0 rows exported
. . exporting table PHYSCLPRTCLENDPNTRLZDBY 0 rows exported
. . exporting table PHYSICALCONNECTOR 0 rows exported
. . exporting table PMCATEGORY 0 rows exported
. . exporting table PMDOMAIN 0 rows exported
. . exporting table PMROLE 0 rows exported
. . exporting table POLICYACTIONBASE 0 rows exported
. . exporting table POLICYCONDITIONBASE 0 rows exported
. . exporting table POLICYGROUPHASPOLICIES 0 rows exported
. . exporting table POLICYSET 0 rows exported
. . exporting table POLLERDATA 0 rows exported
. . exporting table POSTTSSESSIONMETRICS 0 rows exported
. . exporting table PREFERENCESNODE 395 rows exported
. . exporting table PREFERENCESNODE_VALUES 1205 rows exported
. . exporting table PROPERTYNAMEANDVALUE 53349 rows exported
. . exporting table PROTOCOL 0 rows exported
. . exporting table PROTOCOLENDPOINT 15 rows exported
. . exporting table PRTCNFGINF8_LLWDVLNLST 0 rows exported
. . exporting table QRTZ_BLOB_TRIGGERS 0 rows exported
. . exporting table QRTZ_CALENDARS 0 rows exported
. . exporting table QRTZ_CRON_TRIGGERS 4 rows exported
. . exporting table QRTZ_FIRED_TRIGGERS 0 rows exported
. . exporting table QRTZ_JOB_DETAILS 41 rows exported
. . exporting table QRTZ_JOB_LISTENERS 0 rows exported
. . exporting table QRTZ_LOCKS 5 rows exported
. . exporting table QRTZ_PAUSED_TRIGGER_GRPS 0 rows exported
. . exporting table QRTZ_SCHEDULER_STATE 0 rows exported
. . exporting table QRTZ_SIMPLE_TRIGGERS 37 rows exported
. . exporting table QRTZ_TRIGGERS 41 rows exported
. . exporting table QRTZ_TRIGGER_LISTENERS 0 rows exported
. . exporting table QUANTITY 0 rows exported
. . exporting table RCSSSTTNGS3_NTWRKADDRSSS 0 rows exported
. . exporting table RCSSSTTNGS3_VRFNAME 0 rows exported
. . exporting table RCSSSTTNGS4_RTDBGPVRSNS3 0 rows exported
. . exporting table RCSSSTTNGS5_NTWRKADDRSSS 0 rows exported
. . exporting table RCSSSTTNGS5_VRFNAME 0 rows exported
. . exporting table REDUNDANCYSET 0 rows exported
. . exporting table REDUNDANCYSETMEMBER 0 rows exported
. . exporting table REDUNDANCYSETROLE 0 rows exported
. . exporting table REDUNDANCYSETROLESPEC 0 rows exported
. . exporting table REDUNDANCYSETSERVICEDBYSET 0 rows exported
. . exporting table REDUNDANCYSETSPEC 0 rows exported
. . exporting table REDUNDANCYSETSPECHASROLES 0 rows exported
. . exporting table RIPADJACENCY 0 rows exported
. . exporting table RIPPEPSETTINGS 0 rows exported
. . exporting table RIPPEPSTATISTICS 0 rows exported
. . exporting table RIPPROCESSSETTINGS 0 rows exported
. . exporting table RIPPROCESSSTATISTICS 0 rows exported
. . exporting table ROLE_PRIVILEGE 0 rows exported
. . exporting table ROOTSWITCHFORVLAN 0 rows exported
. . exporting table ROUTINGADJACENCY 0 rows exported
. . exporting table ROUTINGAREAINFOSTATISTICS 0 rows exported
. . exporting table ROUTINGAREASTATISTICS 0 rows exported
. . exporting table ROUTINGNEIGHBORINFO 0 rows exported
. . exporting table ROUTINGNEIGHBORINFOSTATISTICS 0 rows exported
. . exporting table ROUTINGPEPSTATISTICS 0 rows exported
. . exporting table ROUTINGPROCESSSTATISTICS 0 rows exported
. . exporting table RTCLENDPNT7_SPPRTDSPDS 0 rows exported
. . exporting table RTLLNK5_DPNDNTLNKRLTSLTPS 0 rows exported
. . exporting table RTLLNK5_LINKSUPPORTEDBYFR 0 rows exported
. . exporting table RTNGNGHBRDSCVRDVPEP 0 rows exported
. . exporting table RUNNINGAPPLICATION 0 rows exported
. . exporting table RUNNINGPROCESS 0 rows exported
. . exporting table RUNNINGPROCESSSTATISTICS 0 rows exported
. . exporting table SBCADJACENCIES 0 rows exported
. . exporting table SBCCALLPOLICYSET 0 rows exported
. . exporting table SBCINSTANCE 0 rows exported
. . exporting table SFCTNCNDTN8_TRFFCFLTRDT 0 rows exported
. . exporting table SOFTWAREAPPLICATIONINSTALLED 0 rows exported
. . exporting table SOFTWAREELEMENTINSTALLED 0 rows exported
. . exporting table SOFTWAREIMAGEINSTALLED 0 rows exported
. . exporting table SPEEDQUANTITYRANGEASYMMETRIC 0 rows exported
. . exporting table STACK 0 rows exported
. . exporting table STACKPORT 0 rows exported
. . exporting table STACKSWITCH 0 rows exported
. . exporting table STATICROUTEENTRY 0 rows exported
. . exporting table STATICROUTETABLE 0 rows exported
. . exporting table STATSAGGREGATED 0 rows exported
. . exporting table STATSCISCOCPU 0 rows exported
. . exporting table STATSCISCOMEMORY 0 rows exported
. . exporting table STATSCISCOPHONECALLSTREAM 0 rows exported
. . exporting table STATSCISCOTBGCALL 0 rows exported
. . exporting table STATSCISCOTBGCALLCHANNELSAUDIO 0 rows exported
. . exporting table STATSCISCOTBGCALLCHANNELSVIDEO 0 rows exported
. . exporting table STATSCISCOTBGCALLSTREAMSOURCE 0 rows exported
. . exporting table STATSCISCOTBGPERIPHERAL 0 rows exported
. . exporting table STATSCISCOTBGPERIPHERALHISTORY 0 rows exported
. . exporting table STATSCISCOTPCALL 0 rows exported
. . exporting table STATSCISCOTPCALLSTREAMSOURCE 0 rows exported
. . exporting table STATSCISCOTPCALLSTREAMTYPE 0 rows exported
. . exporting table STATSCISCOTPPERIPHERAL 0 rows exported
. . exporting table STATSCISCOTPPERIPHERALHISTORY 0 rows exported
. . exporting table STATSCODIANHEALTH 0 rows exported
. . exporting table STATSCODIANSUPERVISORBLADES 0 rows exported
. . exporting table STATSCODIANSUPERVISORFANTRAYS 0 rows exported
. . exporting table STATSCODIANSUPERVISORPOWER 0 rows exported
. . exporting table STATSCODIANSUPERVISORVOLTAGE 0 rows exported
. . exporting table STATSCONDUCTORMCUINFO 0 rows exported
. . exporting table STATSCTMSPROCESS 0 rows exported
. . exporting table STATSCTMSSEGMENTS 0 rows exported
. . exporting table STATSCTSMANSERVICE 0 rows exported
. . exporting table STATSCUCMCPU 222 rows exported
. . exporting table STATSCUCMDBSUMMARY 0 rows exported
. . exporting table STATSCUCMMEMORY 222 rows exported
. . exporting table STATSCUCMPARTITION 1554 rows exported
. . exporting table STATSCUCMSERVICE 16650 rows exported
. . exporting table STATSDEVICEREGISTRATION 0 rows exported
. . exporting table STATSDEVICESTATUS 6 rows exported
. . exporting table STATSHRPROCESSORENTRY 0 rows exported
. . exporting table STATSHRSTORAGEENTRY 0 rows exported
. . exporting table STATSHRSWRUNENTRY 0 rows exported
. . exporting table STATSINTERFACE 0 rows exported
. . exporting table STATSMEDIAFLOW 0 rows exported
. . exporting table STATSPERFMON 0 rows exported
. . exporting table STATSTPCONDUCTORHEALTH 0 rows exported
. . exporting table STATSVCSHEALTH 0 rows exported
. . exporting table STATSVCSPEERS 0 rows exported
. . exporting table STATSVCSRESOURCEUSAGE 0 rows exported
. . exporting table STATSVCSZONES 0 rows exported
. . exporting table STATSVIDEOIPSLATESTAGG 0 rows exported
. . exporting table STATSVIDEOIPSLATESTLATEST 0 rows exported
. . exporting table STLLBL8_IMGINSTLLD5_FEATURES 0 rows exported
. . exporting table STLLBL8_TLLD5_RDWRPLTFRMS56 0 rows exported
. . exporting table STORAGEDEVICE 0 rows exported
. . exporting table STORAGEPARTITION 0 rows exported
. . exporting table STORAGEPARTITIONSTATISTICS 0 rows exported
. . exporting table STPINSTANCE 0 rows exported
. . exporting table STPNESETTINGS 0 rows exported
. . exporting table STRGDVC_INTRNLRSRCRLZDBY 0 rows exported
. . exporting table STTNGS11_CSSDFNSPSSVINTRFCS6 0 rows exported
. . exporting table STTNGS7_CSSDFNSPSSVINTRFCS6 0 rows exported
. . exporting table STTNGS8_CSSDFNSPSSVINTRFCS6 0 rows exported
. . exporting table STTNGS9_CSSDFNSPSSVINTRFCS6 0 rows exported
. . exporting table SWITCHCONTROLCLUSTER 0 rows exported
. . exporting table SWITCHCONTROLCLUSTERMEMBER 0 rows exported
. . exporting table SWTCHCNTRLCLSTRHSCNDDTMMBRS 0 rows exported
. . exporting table SYSTEMNODE 0 rows exported
. . exporting table SYSTEM_PREF_VALUE 0 rows exported
. . exporting table TASKELEMENT 53738 rows exported
. . exporting table TASKELEMENTSPECIFICATION 107 rows exported
. . exporting table TASK_NPTPRMTRS 0 rows exported
. . exporting table TASK_RSLTPRMTRS 53245 rows exported
. . exporting table TCUDEVICE 0 rows exported
. . exporting table TELEPRESENCECONDUCTOR 0 rows exported
. . exporting table TELEPRESENCEEXCHANGE 0 rows exported
. . exporting table TELEPRESENCEMCU 0 rows exported
. . exporting table TELEPRESENCESCHEDULER 0 rows exported
. . exporting table TELEPRESENCESCHEDULERPROPS 0 rows exported
. . exporting table TELEPRESENCESYSTEM 3392 rows exported
. . exporting table TESTMODELOBJECT 0 rows exported
. . exporting table TOPOLGYNEGROUPBELONGSTOCLOUD 0 rows exported
. . exporting table TOPOLOGYIPPEPHASVLANCONFIG 0 rows exported
. . exporting table TOPOLOGYNEGROUP 0 rows exported
. . exporting table TOPOLOGYNEINFO 0 rows exported
. . exporting table TOPOLOGYVLANPORTCONFIGINFO 0 rows exported
. . exporting table TOPOLOGYVTPCONFIGFORNE 0 rows exported
. . exporting table TOPONEGROUPHASNES 0 rows exported
. . exporting table TOUCH 0 rows exported
. . exporting table TPLGYNINF_TROUTERID 0 rows exported
. . exporting table TPPERIPHERAL 0 rows exported
. . exporting table TRAFFICCHARACTERISTICS 0 rows exported
. . exporting table TSEVENT 0 rows exported
. . exporting table TSKGRPSPCHSTSKELMNTSPCS 0 rows exported
. . exporting table TSKSPCFCTN_TINPTPRMTRS3 104 rows exported
. . exporting table TSPROFILEINFO 0 rows exported
. . exporting table TSSESSION 0 rows exported
. . exporting table TSSESSIONTRIGGEREVENTS 0 rows exported
. . exporting table TSSESSION_CONTEXT 0 rows exported
. . exporting table USERACCOUNT 0 rows exported
. . exporting table USEREXTENSIONS 6 rows exported
. . exporting table USERNODE 0 rows exported
. . exporting table USERS 6 rows exported
. . exporting table USER_PREF_VALUE 0 rows exported
. . exporting table VALUEMAPPING 154 rows exported
. . exporting table VIRTUALSWITCHMEMBER 0 rows exported
. . exporting table VLANIDLIST 0 rows exported
. . exporting table VLANIDLIST_VLANIDRANGE 0 rows exported
. . exporting table VLANIDLIST_VLANIDSET 0 rows exported
. . exporting table VLANINTERFACE 0 rows exported
. . exporting table VLANSETTINGSFORNE 0 rows exported
. . exporting table VLANSWITCHPORTSETTINGS 0 rows exported
. . exporting table VLANTRUNKINGSETTINGS 0 rows exported
. . exporting table VSAAAGENTSTATUS 0 rows exported
. . exporting table VSAAENTITY 0 rows exported
. . exporting table VSAASESSIONS 0 rows exported
. . exporting table VSAATESTRESULT 0 rows exported
. . exporting table VSLENDPOINTSTATISTICS 0 rows exported
. . exporting table VSLINKENDPOINTSETTINGS 0 rows exported
. . exporting table VSLPORTSTATISTICS 0 rows exported
. . exporting table VTPSETTINGSFORNE 0 rows exported
. . exporting table XGS_DYNAMICGROUPRULE 89 rows exported
. . exporting table XGS_DYNGROUP_MEMBERTYPE 623 rows exported
. . exporting table XGS_GROUP 92 rows exported
. . exporting table XGS_GROUPATTRIBUTE 0 rows exported
. . exporting table XGS_GROUPINGROUP 87 rows exported
. . exporting table XGS_GROUPMEMBERS
. . exporting partition XGS_GROUPMEMBER_P0 0 rows exported
. . exporting partition XGS_G_P_630630 6 rows exported
. . exporting partition XGS_G_P_630631 2489 rows exported
. . exporting partition XGS_G_P_630632 0 rows exported
. . exporting partition XGS_G_P_630633 0 rows exported
. . exporting partition XGS_G_P_630634 0 rows exported
. . exporting partition XGS_G_P_630635 0 rows exported
. . exporting partition XGS_G_P_630636 0 rows exported
. . exporting partition XGS_G_P_630637 0 rows exported
. . exporting partition XGS_G_P_630638 0 rows exported
. . exporting partition XGS_G_P_630639 0 rows exported
. . exporting partition XGS_G_P_630640 0 rows exported
. . exporting partition XGS_G_P_630641 0 rows exported
. . exporting partition XGS_G_P_630642 0 rows exported
. . exporting partition XGS_G_P_630643 0 rows exported
. . exporting partition XGS_G_P_630644 0 rows exported
. . exporting partition XGS_G_P_630645 2203 rows exported
. . exporting partition XGS_G_P_630646 19 rows exported
. . exporting partition XGS_G_P_630647 234 rows exported
. . exporting partition XGS_G_P_630648 0 rows exported
. . exporting partition XGS_G_P_630649 0 rows exported
. . exporting partition XGS_G_P_630650 0 rows exported
. . exporting partition XGS_G_P_630651 0 rows exported
. . exporting partition XGS_G_P_630652 32 rows exported
. . exporting partition XGS_G_P_630653 0 rows exported
. . exporting partition XGS_G_P_630654 1 rows exported
. . exporting partition XGS_G_P_630655 0 rows exported
. . exporting partition XGS_G_P_630656 0 rows exported
. . exporting partition XGS_G_P_630657 0 rows exported
. . exporting partition XGS_G_P_630658 0 rows exported
. . exporting partition XGS_G_P_630659 0 rows exported
. . exporting partition XGS_G_P_630660 0 rows exported
. . exporting partition XGS_G_P_630661 0 rows exported
. . exporting partition XGS_G_P_630662 0 rows exported
. . exporting partition XGS_G_P_630663 0 rows exported
. . exporting partition XGS_G_P_630664 0 rows exported
. . exporting partition XGS_G_P_630665 0 rows exported
. . exporting partition XGS_G_P_630666 0 rows exported
. . exporting partition XGS_G_P_630667 0 rows exported
. . exporting partition XGS_G_P_630668 0 rows exported
. . exporting partition XGS_G_P_630669 0 rows exported
. . exporting partition XGS_G_P_630670 0 rows exported
. . exporting partition XGS_G_P_630671 0 rows exported
. . exporting partition XGS_G_P_630672 0 rows exported
. . exporting partition XGS_G_P_630673 2 rows exported
. . exporting partition XGS_G_P_630674 6 rows exported
. . exporting partition XGS_G_P_630675 0 rows exported
. . exporting partition XGS_G_P_630676 0 rows exported
. . exporting partition XGS_G_P_630677 0 rows exported
. . exporting partition XGS_G_P_630678 0 rows exported
. . exporting partition XGS_G_P_630679 0 rows exported
. . exporting partition XGS_G_P_630680 0 rows exported
. . exporting partition XGS_G_P_630681 0 rows exported
. . exporting partition XGS_G_P_630682 4 rows exported
. . exporting partition XGS_G_P_630683 0 rows exported
. . exporting partition XGS_G_P_630684 0 rows exported
. . exporting partition XGS_G_P_630685 0 rows exported
. . exporting partition XGS_G_P_630686 0 rows exported
. . exporting partition XGS_G_P_630687 0 rows exported
. . exporting partition XGS_G_P_630688 3 rows exported
. . exporting partition XGS_G_P_630689 0 rows exported
. . exporting partition XGS_G_P_630690 0 rows exported
. . exporting partition XGS_G_P_630691 0 rows exported
. . exporting partition XGS_G_P_630692 0 rows exported
. . exporting partition XGS_G_P_630693 0 rows exported
. . exporting partition XGS_G_P_630694 0 rows exported
. . exporting partition XGS_G_P_630695 0 rows exported
. . exporting partition XGS_G_P_630696 0 rows exported
. . exporting partition XGS_G_P_630697 0 rows exported
. . exporting partition XGS_G_P_630698 0 rows exported
. . exporting partition XGS_G_P_630699 1 rows exported
. . exporting partition XGS_G_P_630700 0 rows exported
. . exporting partition XGS_G_P_630701 1 rows exported
. . exporting partition XGS_G_P_630702 0 rows exported
. . exporting partition XGS_G_P_630703 0 rows exported
. . exporting partition XGS_G_P_630704 2489 rows exported
. . exporting partition XGS_G_P_630705 0 rows exported
. . exporting partition XGS_G_P_630706 0 rows exported
. . exporting partition XGS_G_P_630707 33 rows exported
. . exporting partition XGS_G_P_630708 2456 rows exported
. . exporting partition XGS_G_P_630709 42 rows exported
. . exporting partition XGS_G_P_630710 0 rows exported
. . exporting partition XGS_G_P_630711 0 rows exported
. . exporting partition XGS_G_P_630712 0 rows exported
. . exporting partition XGS_G_P_630713 0 rows exported
. . exporting partition XGS_G_P_630714 253 rows exported
. . exporting partition XGS_G_P_630715 0 rows exported
. . exporting partition XGS_G_P_630716 33 rows exported
. . exporting partition XGS_G_P_630717 2203 rows exported
. . exporting partition XGS_G_P_630718 3481 rows exported
. . exporting partition XGS_G_P_630719 6 rows exported
. . exporting partition XGS_G_P_3098699604 1570 rows exported
. . exporting partition XGS_G_P_3098699605 471 rows exported
. . exporting table XGS_VDOBJECTGRAPHRULE 0 rows exported
. . exporting table XGS_VD_OBJECT_GRAPH 0 rows exported
. . exporting table XMPPRIVILEGE 0 rows exported
. . exporting table XMPROLE 7 rows exported
. . exporting table XMPTASK 0 rows exported
. . exporting table XMPUSERDOMAINROLE 0 rows exported
. . exporting table XMPUSERGROUPDOMAINROLE 0 rows exported
. exporting synonyms
. exporting views
. exporting stored procedures
. exporting operators
. exporting referential integrity constraints
. exporting triggers
. exporting indextypes
. exporting bitmap, functional and extensible indexes
. exporting posttables actions
. exporting materialized views
. exporting snapshot logs
. exporting job queues
. exporting refresh groups and children
. exporting dimensions
. exporting post-schema procedural objects and actions
. exporting statistics
Export terminated successfully without warnings.
^@Backup completed successfully..
I can see that the user is logged into the FTP Server. A file has been also created 544415 kb... (prime-141024-1022.tar.gpg) So it works fine with CLI but I want to get it done with GUI and a schedule.
Thanks so far! :-)
10-24-2014 03:02 AM
Thanks for update....
So, u mean to say that through CLI , backup works successfully for ftp and sftp but fails when backup is taken through GUI for ftp/sftp.
regds,
aman
10-24-2014 05:02 AM
Yes that is right!
10-24-2014 07:56 AM
Hi Frank,
please refer the link if it helps
https://supportforums.cisco.com/discussion/12107536/cisco-prime-95-failed-generated-assurance-backup
I have been trying to find the bug but could not .
regds,
aman
