06-18-2015 12:50 PM
Hi everyone
I've been trying to connect to Cisco Prime Collaboation Assurance 10.6 with Filezilla through SFTP protocol but I could not connect.
Do you know if I have to make some different to achieve the connection on CPC Server?
Attach the image with the error.
Thank you
06-19-2015 01:04 AM
Hi Arthur,
The attached snasphot shows that you are trying to use ftp protocol while the response message from sftp server requires SSH.Can u change to SSH and check?
Further.I can see few bugs related to backup/restore
regds,
aman
06-19-2015 02:01 PM
Hi Aman
Thank you for you answer.
I tried using this address sftp://XX.XX.XX.XX, but now I have another error:
06-20-2015 04:11 AM
Hi Arthur,
Suggest opening TAC case since u are able to login from CLI through SSH which uses TCP port 26 with same credentials ?
Are u trying to take backup?
regds,
aman
06-22-2015 04:13 PM
Hi Aman
I followed the next steps and now it's working
Arthur
06-23-2015 04:23 AM
thanks for updates[+5]
Is this documented in Cisco?
regds,
aman
06-23-2015 08:45 AM
Yes it is, the TAC helped me
Arthur
