Cisco Prime Collaboration connection SFTP
Hi everyone
I've been trying to connect to Cisco Prime Collaboation Assurance 10.6 with Filezilla through SFTP protocol but I could not connect.
Do you know if I have to make some different to achieve the connection on CPC Server?
Attach the image with the error.
Thank you
6 Replies 6
Aman Soi
Hi Arthur,
The attached snasphot shows that you are trying to use ftp protocol while the response message from sftp server requires SSH.Can u change to SSH and check?
Further.I can see few bugs related to backup/restore
PCA restore fails when backup is done over ftp.
CSCum87638
PCA Backup requires SSH access for SFTP causing failures
CSCum88682
Symptom:
When trying to generate a backup from Prime Collaboration Assurance and store it to a secure SFTP server which is blocking SSH, the backup job will fail
Conditions:
Attempt to use a secure SFTP server blocking SSH.
Workaround:
Fix is available in Service Pack 1
regds,
aman
Hi Aman
Thank you for you answer.
I tried using this address sftp://XX.XX.XX.XX, but now I have another error:
Status: Connecting to XX.XX.XX.XX:26...
Response: fzSftp started, protocol_version=2
Command: open "root@XX.XX.XX.XX" 26
Command: Pass: ***********
Error: Authentication failed.
Error: Critical error: Could not connect to server
However, user and password are correct, I tried to login with the same credentials through CLI and I didn't have any problem.
It could be a root user problem?
Regards.
Arthur
Hi Arthur,
Suggest opening TAC case since u are able to login from CLI through SSH which uses TCP port 26 with same credentials ?
Are u trying to take backup?
regds,
aman
Hi Aman
I followed the next steps and now it's working
  1. Login as root, enter the following below, more than likely you are in root patch mode.
  2. Input: passwd (this will ask to change the passwd but you can use the same one that you already have)
  3. Cd /opt/emms/emsam/bin/
  4. ./enableRoot.sh (this will restart the ssh process)
  5. After this you should be able to login into winscp or filezilla.
Arthur
thanks for updates[+5]
Is this documented in Cisco?
regds,
aman
Yes it is, the TAC helped me
Arthur
