Cisco Setup for Voice
bilaljaved
Dear Sir,
I have DVD of Cisco CCM6.0.1.iso, one configured voice gateway AS5400 with TDM E1s, and one blank server with good specs.
Can you please guide how to setup voice network with CCM?
Previously we are using voice network using AS5400, Nextone(softswitch) and TDM provider.
Please guide. Thanks
Bilal
Jaime Valencia
Start by getting the DVD in the server and following the install wizard, then you can proceed to configure the AS5400 as an H323 GW.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
