Cisco Unity Connection 2.0 user problem
I have a problem with Unity Connection 2.0
When i set ut i new user i get this message.
The credential minimum length check failed
I have tried to create a new user template.
The licences seens OK 11 User left.
roboliveira
Hi there, Did you ever find an answer to this issue? I am running into the same problem.
TIA
~ Rob Oliveira ~
joshhaleaos
You need to make sure that your password in the user template is matching what you have configured in authentication rules.
