Cisco Unity Connection 8.5
hectorgo
Hi im having a weird problem with unity connection 8.5 , I installed the spanish(Colombia) Locale and it works fine but the problem is when a i call a user and goes to unity for CFNA if attemp forward is set to spanish the system says "System Cannot Deliver Message Try again Later" In spanish , but if change attempt forward to use english locale i can leave messages with no problem. Please Help.
Rob Huffman
Hi Hector,
You are likely hitting the issue detailed in this thread
https://supportforums.cisco.com/message/3386074#3386074
Cheers!
Rob
That was it, Thanks!!!
