Cisco Unity Connection 8.x installation on MCS server physically
mohsin majeed
Level 2
Level 2
Dears,
One of the customers has ordered the below; I have to install Cisco Unity Connection on MCS Server never experienced before and couldn't find much help to install. Please guide me and i have some questions
- Looking at below BoQ; is CUC software preloaded on this server? if so, please guide me through rest of the procedure to complete the installation.
- Is this solution come with the CUC software DVD? If so, again need the installation proceedure.
- Can we install using Bootable USB?
- Looking at supporting platform list i noticed 8.6 must need 6GB RAM, So will i use 8.5 & 8.0 ?
- If CUC software is not preloaded then from where i can get this software because customer asked that we have to arrange the software.
- I need initial installation procedure infact. I already know the integration configuration with cucm.
Will appreciate your help
MCS-7835-I3-IPC2
Bare Metal MCS 7835 IBM server 1x5504 CPU, 4GB RAM, 2x300HDD
EA
CON-SCAN-MCS78IP2
SC ADV 8X5XNBD Bare Metal MCS 7835 Months Duration: 12.0
EA
CAB-ACU
AC Power Cord (UK), C13, BS 1363, 2.5m
EA
UNITYCN8-K9
Unity Connection 8.x Software
EA
CON-ESW-UNITYCN8
ESSENTIAL SW Unity Connection 8.x Months Duration: 12.0
EA
UNITYCN8-7835
Unity Connection 8.x for 7835
EA
UNITYCN8-HA-7835
Unity Connection 8.x HA for 7835
EA
UNITYCN8-HA-PAK
Unity Connection 8.x HA PAK
EA
SPEECHVIEW-DEMO
SpeechView Demo License for 50 users for 6 months
EA
UNITYCN8-USR
One Unity Connection 8.x User - All user Features
EA
828
UCSS-U-MSG-1-1
UCSS for Unity or Unity Connection - 1 user One Year Sub Duration: 12.0 Months
EA
828
Jaime Valencia
Not sure where they got that, all MCSs have been sold out many months ago.
I don't even think you can order CUC 8.x right now.
If it's preloaded, once you boot the server, fill in the blanks, that's all you need to do, follow the wizard, and fill in the blanks. You can review the CUC installation guide on cisco.com.
No, you need a bootable DVD for the install.
Yes, the platform has only 4GB as originally shipped, so you cannot go beyond 8.5, what version?? is up to you or your customer.
If you don't have the bootable media, you'll need to order via PUT, again, not sure if you can as it's already EOS, if not, work that with TAC or your AM.
Again, the installation is a wizard, the same kind you see in CUCM or CUPS/IM&P, it's a fill in the blanks procedure. The CUC installation guides are all available under the CUC documentation on cisco.com
java
if this helps, please rate
5 Replies 5
Jaime Valencia
java
Thanks for you reply,
Can i download Bootable media if i get service contract detail from customer.
Can you plz explain this statement "order via PUT"
If i download the below, will it work or is it something else?
There are NO BOOTABLE media images on cisco.com, those are ONLY for upgrades.
PUT = Product Upgrade Tool
http://tools.cisco.com/gct/Upgrade/jsp/productUpgrade.jsp
Again, not sure if you can get it there as it's already EOS.
java
[+5] to Jaime .
Hi Mohsin,
UCXN 8.x is already end of sale but is supported till Aug.2017.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unity-connection/eos-eol-notice-c51-731028.html
http://www.cisco.com/c/en/us/products/unified-communications/unity-connection/eos-eol-notice-listing.html
As suggested by Jaime, you can involve TAC to have Bootable publish for you else, if you have UCSS contract  and VM available ,you can order latest version through PUT /get Bootable of 10.x and install it.
regds,
aman
Hi Mohsin,
Cisco UCM / UCXN 8.x is been EoS as Jamie has mentioned, however 8.6 is under support till 2017 as Aman Soi has mentioned.
This means that no customers can order any 8.x licenses, however of course they can order 10.x or 9.x and install 8.x if they wish.
If I were you, I would recommend the customer to purchase the new licenses for 10.x and use them, however the 9.x onwards its Virtual ONLY i.e. you will have to use it on VMWare VMs either on the Cisco's recommended TRCs only.
Here is the list of it.
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware
Please feel free to let us know if you have any other queries or concerns.
