Cisco Unity connection Asked for recovery disk
mohammad saeed
Level 5
Level 5
Dear Guys,
one of my project I have CUC and the customer suddenly complained about that the CUC server not running through the VMware and when I went to console I saw these messages:
An error occurred during the file system check.
Insert the recovery disk and select the appropriate
Insert the recovery Disk then press ENTER:
Actually I have recovery file I took it before by disaster recovery! but how can I use it for this case!
If I removed the CUC and install it again how can I re-licensed again,,,Will I lose the license?
Thanks for all
Mohammad Saeed
6 Replies 6
Deepak Rawat
Refer to below document, you can use the same steps for CUC as well:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118948-technote-cucm-00.html
Deepak
Thanks Deepak,
Can I use Unified Communication manager recovery file for CUC?
Yes, you use the same recovery disk for CUC.
Thanks Mohammed,
Actually I was made a recovery disaster files before that, if I reinstall it again and recover the files from inside CUC how could that help? and what about the license? can I reuse it again?
What is the CUC version??
And yes, usually a reinstall and DRS restore is better than a system that was fixed by the recovery disk
java
if this helps, please rate
Manish Gogna
Hi Mohammad,
Please verify if there was an unclean shutdown as per the following as it may require a rebuild
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116717-trouble-cucm-shutdown-00.html
Manish
