CISCO VG350 Gateway Protocol Issue With CUCM
amalmichaelvj
Hello Team,
We need to add Cisco VG350 Analog Gateway in Cisco CUCM 12 for connecting all my analog phones in CUCM.For that we have MGCP/SCCP Protocols .
In my VG350 analog Gateway I have VIC2-4FXO card for connecting pstn Connection..
In Sccp Protocol my VIC2-4FXO port in Not listed in VG350..
Does SCCP protocol support VIC2-4FXO Port??
If we need to add VG350 as MGCP does which all features are supported..
When i checked the documents all features are not supported in MGCP
Kindly clarify these features are supported in MGCP
Call Forward All(*4 -> to enable,*5-->to disable)
Conditional Forwarding
Call Transfer (Blind Transfer & Consult and transfer)
Call Pickup
Redial (*7)
6
Call Waiting
7
Short Codes
8
Speed Dials
9
Call Back no Answer(*9)
Conference (*3)
11
Directory
12
Music on Hold
13
BLF on console (off hook/on hook)
14
Call Barging for operator console
15
Return of calls on console if no answer during transfer for operator console
16
Direct transfer of calls during welcome message
17
Multiple phones with same extn numbers with privacy
Jaime Valencia
There are no supplementary features with MGCP
java
if this helps, please rate
Jonathan Schulenberg
MGCP was designed as a trunk-side protocol while SCCP was designed as line-side. The gotcha is faxing: protocol-based T.38 fax relay is only supported over MGCP. For this reason, most people use MGCP since faxing is the most common use case for FXS ports these days. Hookflash and feature access codes that SCCP provides are rarely required.
You can technically have both on the same chassis but you have to be very careful only to configure the modules you intend to use on one gateway or the other. In my opinion, this is one of those “just because you can do it, that doesn’t mean you should” situations.
