CLI commands for checking licensing in Xpressway-Core 8.11.4
dmooreami
Level 3
Level 3
Can anyone help?
I need the  the command line “command/syntax” to check licensing of Expressway Core.
We have a clone of our 8.11.4 in a sandbox and are testing if the loss of licensing due to a non-shutdown reboot of the vm can be repeated.
I know that core gives ample notice of licensing issues in the webgui, but how do I check via the command line?
Jaime Valencia
The Expressway administrator guide has the reference for all the xCommands, have you looked there?
java
if this helps, please rate
Yes, and none were helpful, that's way I asked here.
there are about 20+ versions of the xcommands. They can be stand-alone or combined together for another 20+ commands.
We put windows 10 VM on the isolated subnet and used webgui where the info was blazing out in big red alerts.
