click to call with CUCI-LYNC
John Vincent
I seem to remember on a Cisco demo that using CUCI-LYNC (CUCI-MOC at the time) with the click to call addins enabled you to just click on
a phone number in IE or Word or other enabled apps without having to highlight the number, right-click, and then choose call...  We are running UCM 8.5, CUCI-LYNC on top of MOC 2007 R2.  Does anyone know if "clickable" phone number links can be done in IE, etc?
stowellp
Hi John,
We're using CUCILYNC 8.5, MOC 2007 R2, Office 2007 and UCM v8.02
If a number is in an office application or IE (and in the correct format) you can right-click and call, or call with edit, but you cannot just click once to dial.
Cheers,
Phil
