Click to Call
Pericles31
I have installed click to call on my pc but when I try to use it doesn't work. Appears the window for editing and call and the option to call directly but when I try I get the following error: "There was an HTTP error. " In addition, the SW can not call from the outlook.
What can i do?
Marcel Ammann
Level 3
Level 3
Hello Juan,
which version of Click2Call do you use?
If you use the version 8.0 there are some bugs:
https://cisco-support.hosted.jivesoftware.com/message/3240788
If you want to dial from outlook you can download Cisco TSP from the CUCM plugin page.
Please rate helpful posts.
Kind regards,
Marcel Ammann
Marcel Ammann
Level 3
Level 3
Hello Juan,
Kind regards,
Marcel Ammann
Thanks Marcel for you answer.
Cloud_telephony
Hello @Pericles31
May I know which version of click to call you use? you must have to use some trustful click to call service provider, which is assured you with their services.
https://www.cloud-connect.in
