click_to_call10.6.7
engdelta1
Hello ,
 In Click to call version 10.6.7 I cant find  indication that a voicemail is left in the voicemail box.
is there  a way to have  number indication how many mails have not been listened to ?
or it is not  a feature in click to call
thanks
Jaime Valencia
Not sure what C2C you're talking about, but for the most part, they're not an IP Phone, and you only get the click to call capabilities, nothing else.
java
if this helps, please rate
Thanks jaime ,
I was in need to confirm that click to call doesn't have this feature
tomjrcanlas01
I believe click-to-call is a  stand-alone feature. Voicemail indicators are often configured on the CRM/phone system being used. We're currently using an integration solution called Tenfold for data and call management. www.tenfold.com
