Cluster and Sub-Cluster average sustained bandwidth
DonweinerCO
Working on a CoW deployment where we will split IM&P subclusters across the WAN. The SRND indicates we should allot 5 Mbps between servers in a subcluster, and 5 Mbps between subclusters. Have you been seeing this type of bandwidth between IM&P servers? We can account for spikes up to these levels but need to set expectations with the WAN team for average bandwidth consumption. Any help is appreciated.
dokurian
5mb requirement is  primarily for initial and/or new user db sync  to make sure all data is synced/replicated properly across the nodes/cluster. a
5mb addresses the need for initial user db sync to be successful  and within reasonable time.
Doys K
