Cluster design with subscriber 10.X on VM to exisiting MCS 7835I running with v8.6
Siva Mantri
At present CUCM is running with single node MCS 7835I (v8.6) in cluster. Now planning to implement cluster by building subscriber with version 10.X  on VM to existing MCS 7835I which remains as publisher.
Does cluster support dissimilar hardware and software mismatch setup  ?
Also having plans to upgrade MCS H7835I to 9.1 later, is it possible ?
Thanks in advance
Aman Soi
You can have dissimilr Harwdare in clsuter provided that version supports.
CUCM 10.x is supported on VM and not on MCS.
what is exact model of MCS 7835?
you can also refer H/W compatibility matrix
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html
regds,
aman
Thanks aton Jaime Valencia & Aman Soi
Now I understood. Publisher and subscriber in a cluster should have same version.
Here is the hardware details
MCS7835I3-K9-CMD2
HW Platform        : 7835I3
Processors          : 1
Type                      : Intel(R) Xeon(R) CPU       (E5504  @ 2.00GHz)
CPU Speed         : 2000
Memory                 : 4096 MBytes
Hi ,
the link shows existing HW is supported for version 9 but I would ask you to involve Cisco SE prior to doing this migration.
regds,
aman
Jaime Valencia
No, ALL servers in a cluster need to run the exact same release version, and as Aman pointed out, 10.x ONLY runs over ESXi, so, either you build another 8.6 server on MCS/UCS, or you migrate all to UCS if you wish to run 10.x
java
if this helps, please rate
