CLUSTER UNITY CONNECTION 8,5
Wilson Freire
High-availability problems in the cluster when I remove the connection Unity Publisher Subscriber is marketed as the primary but only I have a message "the system is not available try again later"
Markus Schneider
could you please be a bit more specific what you did and what happened?  How did you remove the Publisher (i.e. did you power it off, unplug the ethernet cables, etc)?  Was it working prior to the failure (i.e. were you able to call either subscriber or publisher and the respective server answered the call successfully and the cluster status was such that the publisher was primary and subscriber secondary)?
