Showing results forĀ
Search instead forĀ
Did you mean:Ā
CMB Legacy error
Gaurav Thakur
I have installed CMB 7.1.3 in our lab and configured it to communicate with EIM 9.0.1 setup. when I start CMB service it give me a alert.
Description
Collaboration[1]: RMI Link to 10.10.61.120 is down: Reason  Transport link is down.
On checking the logs I see below exception. I have veriffied that the remote and local password are set correctly which is there in collobration.xml file.
06/11/2013 05:37:44.349 ERROR WARNING common.2 LegacyError com.cisco.io.net.rmi.RmiDriver Authenticate "RmiDriver: rmi://10.10.61.120:1099/Connection_CCS_BAPI" com.cisco.io.net.PasswordNotValidException - Legacy error: Password authenticate failure
Could you please guide me in right direction to troubleshot this issue?
Thank you.
Gaurav Thakur.
Gaurav Thakur
Update DB with correct password to fix the issue.
